 Post subject: Pending bug - problem with 2 disks
PostPosted: January 20th, 2010, 19:42
I have two disk with similar problem called "pending bug" i suppose..
1. Seagate Barracuda 7200.10 3,5" ST3250410AS
I read the http://www.acelaboratory.com/forum/view ... 05240ce62e
I try this, but something is wrong. Log:
Test : HDD initialization by utility...
Switch HDD PWR supply.... : No
Terminal Reset........... : Yes
Terminal work speed...... : 9600
Used LDR................. : C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SeagateBara\Barracuda 7200.10 NHawk Plus\ST3250410AS-4.AAA-6RYKBGFQ\Data\LDR\SgLDR.ldr
Loaded from.............. : G:\PC3K\NewTask2\LDR\SgLDR_Init.ldr
Work with HDD through.... : ATA
App...................... : Loading from LDR
Used modifications....... : Fix 'Pending Bug', Fix 'Pending Bug' (fix 2), Fix 'Not Handled Soft Path' Bug
Load Ovl 0............... : No
Initializing Safe Mode...
Switching HDD power supply OFF
Switching HDD power supply ON
HDD SpinUp.............................. : Ok
Reading boot SA elements...
Reading boot adaptives.................. : Ok
Reading Reserve track defect list....... : Ok
App patching...
Downloading App code...
App code downloading.................... : Ok
Starting App code...
cmd 2A, params 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
(P
Buzz HM SFI
cmd
Drive is not ready
Starting App code....................... : Ok
Cannot start App!
Cannot start App!
Can You help me with this?
2. Seagate Momentus 5400.4 2,5" ST9250827AS
This disk is not supported by PC3K UDMA right?
It is possible to use "pending bug" anyway?
I try but it don't work too. Similar effect.
Maybe somewhere i made a mistake? Any ideas?
 Post subject: Re: Pending bug - problem with 2 disks
PostPosted: January 22nd, 2010, 3:42
There could be matching issues with the loader that you have .
PostPosted: January 22nd, 2010, 6:20
Maybe problems with heads/bad media also. I think DSC and DRDY is possible after long wait. Where did you get LDR from? Was from a donor drive?
PostPosted: January 22nd, 2010, 8:38
I read LDR directly from the patient disks. It takes a little bit long, but it read correctly.
Users browsing this forum: Google [Bot] and 104 guests
