 Post subject: Resolder tower stacked TSOPs
PostPosted: January 22nd, 2010, 18:39
Hello boys and girls! Any clue how to resolder stacked flash chips that have a thin pcb in between the pins? I need to put them back together, and back on the board. I put the first chip on the board, then blasted the chip with hot air and set the pcb on top with a tweezers, but the pcb spacer does not sit on the pins very well. I have a ton of these to resolder! YIKES! Any guesses?
Thanks!
 Post subject: Re: Resolder tower stacked TSOPs
PostPosted: January 23rd, 2010, 8:43
Online
I have seen stacked ICs many times, but there never was any PCB in between.
Could you post pics?
PostPosted: January 25th, 2010, 10:59
Here is an example. I have already pulled the chips apart on the one that I have. Proving to be quite difficult! I would normally bend the pins over on solder them directly to the bottom chip, but that won't fly with this customer.
PostPosted: January 26th, 2010, 5:17
What device are these chips from?
PostPosted: January 26th, 2010, 17:18
These chips are from an SSD. The photo is not of the device, just an example I found. Exact same setup though.
PostPosted: January 28th, 2010, 17:08
Online
hmm, never seen such setup...
I have no good idea to resolder tons of this. probably infrared can help here...
Users browsing this forum: No registered users and 43 guests
