 Post subject: WD10EVAS-00D7B1 is there a solution to this?
PostPosted: February 3rd, 2010, 8:16
I have the above drive with what I understand is a common problem. I can read all SA modules, all read heads test good but I can not read any LBAs. I also have the following error, which I understand is common to this type of failure...head0 and head1 both show cylinder -1 with an identical error, all 169 other tracks test good. I was advised by one forum member that tis was a common error and simply rectified...just read the PC3K maual. I did but didn't see anything helpful. Any suggestions? Oh yes, regenerating the translator didn't work.
Thanks,
GB
 Post subject: Re: WD10EVAS-00D7B1 is there a solution to this?
PostPosted: February 3rd, 2010, 8:18
Translator is fine, just not loaded due to other errors, all mentioned in previous topics...
PostPosted: February 3rd, 2010, 12:55
could u link plz?
PostPosted: February 3rd, 2010, 13:51
Yes Please.
Thanks,
GB
PostPosted: February 3rd, 2010, 13:55
If you have genuine PC3K UDMA then you'll have access to the forum, the answers there.
But of course you'll need PC3K UDMA to apply the solution.
PostPosted: February 3rd, 2010, 14:15
U meen Yareks workaround ?
Users browsing this forum: Google [Bot] and 220 guests
