Post new topic Reply to topic  [ 26 posts ]  Go to page 1, 2  Next
 Post subject: WD10EAVS-32D7B1 unable to read data
PostPosted: January 21st, 2010, 15:48
I have WD10EAVS-32D7B1 able to read all of its modules & ROM, In initial structure test Mod 24 copy 0 & 2D copy 0 were bad so I replaced with copy 1 now structure test is ok all of its modules are ok but unable to read data did regenerate translator but same result.
Can someone help ?
 Post subject: Re: WD10EAVS-32D7B1 unable to read data
PostPosted: February 3rd, 2010, 8:26
Did you get this resolved? I have the same problem.
Thanks,
GB
PostPosted: February 3rd, 2010, 10:36
Having the same problem with WD 1TB, but I'm working on it.
I'll post the results soon.
Good luck guys
PostPosted: March 4th, 2010, 10:08
Allow me bo bump this one. Have 3 cases with these simptoms... SA all good all readable yet nada LBA.
PostPosted: March 4th, 2010, 10:15
The problem has been discussed in previous topics, along with the solution...
PostPosted: March 4th, 2010, 10:36
hddguy , amigo, why do u even bother ? I searched the forum for this , i did find several topics dealing with it and none of em had a solution. I seen u BTW saying exactly the same in other post. Is that ur calling in life ?
Swersig had the problem with heads in his case.
ITconcepts topic did not contain any usefull info.
Several TVS related issue in other ones.
PostPosted: March 4th, 2010, 10:47
Head(s) problem.
PostPosted: March 4th, 2010, 10:52
unknown20010 wrote:
Head(s) problem.
Even with SA reading in perfect shape?
PostPosted: March 4th, 2010, 10:59
SA and data are written in different densities, maybe this is reason SA can read...
PostPosted: March 4th, 2010, 11:04
Alexii wrote:
unknown20010 wrote:
Head(s) problem.
Yes. WD Royal drives may passport just fine, but if a head is bad, translator is not loaded correctly, and access to LBAs is denied. Not a hard problem to overcome if you have the proper tools.
http://www.datasaversllc.com
PostPosted: March 4th, 2010, 11:09
Well got the tools ( PC3k ). Now i am wondering if u are sugesting head transplant or Swersigs hot swap?
PostPosted: March 4th, 2010, 12:19
why not both? :mrgreen:
PostPosted: March 4th, 2010, 12:35
Thats ur attempt at being funny ? Lame troll is lame. =)
A-ten-hut. Left shooulder HUT! http://forums.worldofwarcraft.com/index.html?sid=1 Marche!
Ull feel right at home there Spaz.
PostPosted: March 4th, 2010, 13:12
He might be right on a spot, but you don't even paing any attention to it. :roll:
www.datarecoveryne.com
PostPosted: March 4th, 2010, 13:17
thats the last time I give you advice.
PostPosted: March 4th, 2010, 13:23
I have had some of these cases that could only be solved through Head Replacement, and others I could solve with hotswap, many I can recover without any donor. Some cases require a combination of both.
You now know the problem, you are more than halfway to the solution. Maybe fzabkar knows........
PostPosted: March 4th, 2010, 13:25
seems redundant does it not ? If i find a compatible donor to do a head swap ill get to my LBA with no need for hot swap. And a smiley at the end of criptic message does not give it much credo. Same with u specialist. Like a dolphin who talks in riddles. All "might be's" and rolling eyes... This gets so tiering lately... Its like walking through a swamp...Diging smart alec remarks and bullshit statements for a grain of truth.
For what its worth if i was not aimed as a joke , but as help - i apologies Spaz. I thought it was an Empty comment for post count. But i repeat my statement. IF i get healthy and compatible heads and put them into a patient drive, why would i need hot swaps ?
PostPosted: March 4th, 2010, 13:30
In some cases head replacment is successful, but some heads may not be aligned. One way in which a HotSwap can help in such situations can sometimes provide access to SA and in fact data.
I can see from your posts that while you are eager, you are not very experienced. Also, you seem quite confident that a head replacement procedure will work for you. Have you tried this before?
PostPosted: March 4th, 2010, 13:31
Yet another cryptic Dolphin =) And childish ending too.
PostPosted: March 4th, 2010, 13:40
I apologise, let me just write here to you solutions to all problems I have worked hard for, and spent a lot of time on, for you and every other newbie here to leech off me.
you have already identified the failure is related to at least one head, you know of 2 potential solutions including Head Replacement and hotswap, even this is too much information to give out in my opinion, and you still are not thankful for it and want even more.
Rather than argue and criticise the people actually trying to help you, why not apply one of these solutions to your clients HDD and I wish you good luck.
Am glad I am not your customer and the WD is not mine...
