 Post subject: nEED heelp please
PostPosted: February 8th, 2010, 4:09
hi
Am actually new to this forum and basically I have been doing extensive research regarding on hard drives
However am kinda confused in some parts
basically I have a Maxtor Diamond Max plus 9 Hard drive
Which has basically just switched off itself
in other words the drive will no longer power up
I plugged into a USB external adapter to check and I am guessing that its a PCB issue
the reason being the drive was working perfectly fine and then all of sudden it just powered off and since then it wont power on at all
Now I have a second Dell machine which was bought exactly the same time and inside that Dell machine it has the exact Same drive
with the Same
Number on the EEProm chip
Same date
Same Code
Same Firmware on the sticker
Same size
Same Model Number
So my questions is that basically after reading a few threads on the forum it states that you would need to change / swap the chip over on the logic and that requires soldering.
So seeing as what I stated above regarding the exact same drive which I have.... Would I need to still Swap the chip over?
I have found a site which sells PCB and basically they have the exact PCB for my hard drive
here is the site: http://www.onepcbsolution.com
regards
Unadkat
 Post subject: Re: nEED heelp please
PostPosted: February 8th, 2010, 21:03
I done it and it worked like a charm. the issue was with the PCB and after swapping it over, it worked straight away without any problems at all.
regards
unadkat
:D
PostPosted: February 9th, 2010, 4:09
Maxtor Plus 9 are very forgiving on PCB swap, mostly they do not have an external ROM.
PostPosted: February 9th, 2010, 14:51
thanks mate.. however what if the drive did have an external ROM, then what would that mean if u dont mind me asking ? and How would I bypass that issue?
regards
unadkat
PostPosted: February 9th, 2010, 15:15
You would have to transfer it over, which on these is fairly straightforward.
Users browsing this forum: No registered users and 269 guests
