 Post subject: Quantum Fireball lct (20GB, FAT32) DOWN!!!
PostPosted: February 11th, 2010, 22:15
Hello, i dont know what to do, here are some of logs:
Testdisk:
Analyse Disk /dev/sdc - 20 GB / 19 GiB - CHS 2637 240 63
Geometry from i386 MBR: head=240 sector=63
test_FAT()
1 * FAT32 LBA 0 1 1 2635 239 63 39856257
sector_size 528
cluster_size 48
reserved 4132
fats 2
dir_entries 16
sectors 16
media F8
fat_length 4096
secs_track 4159
heads 4336
hidden 268439615
total_sect 308295809
check_part_i386 failed for partition type 0C
get_geometry_from_list_part_aux head=240 nbr=2
get_geometry_from_list_part_aux head=8 nbr=2
get_geometry_from_list_part_aux head=16 nbr=2
get_geometry_from_list_part_aux head=32 nbr=2
get_geometry_from_list_part_aux head=64 nbr=2
get_geometry_from_list_part_aux head=128 nbr=1
get_geometry_from_list_part_aux head=255 nbr=1
Current partition structure:
Invalid FAT boot sector
Ask the user for vista mode
Allow partial last cylinder : No
search_vista_part: 0
search_part()
Results
interface_write()
No partition found or selected for recovery
search_part()
file_pread(6,2,buffer,39875234(2637/60/15)) lseek err Invalid argument
file_pread(6,1,buffer,39875234(2637/60/15)) lseek err Invalid argument
Results
interface_write()
simulate write!
write_mbr_i386: starting...
write_all_log_i386: starting...
No extended partition
New options :
Dump : No
Cylinder boundary : Yes
Expert mode : No
Interface Advanced
test_FAT()
sector_size 528
cluster_size 48
reserved 4132
fats 2
dir_entries 16
sectors 16
media F8
fat_length 4096
secs_track 4159
heads 4336
hidden 268439615
Change partition type:
Directory /
17170437 -rwxr-xr-x 0 0 327944 7-Aug-1980 01:00
17694725 -rwxr-xr-x 0 0 327952 15-Aug-1980 01:00
18219013 -rwxr-xr-x 0 0 327960 23-Aug-1980 01:00
18743301 -rwxr-xr-x 0 0 327968 31-Aug-1980 01:00
19267589 -rwxr-xr-x 0 0 327976 7-Sep-1980 01:00 !
19791877 -rwxr-xr-x 0 0 327984 15-Sep-1980 01:00 )
20316165 -rwxr-xr-x 0 0 327992 23-Sep-1980 01:00 1
20840453 -rwxr-xr-x 0 0 328000 1-Oct-1980 01:00 9
21364741 -rwxr-xr-x 0 0 328008 7-Oct-1980 01:00 A
21889029 -rwxr-xr-x 0 0 328016 15-Oct-1980 01:00 I
22413317 -rwxr-xr-x 0 0 328024 23-Oct-1980 01:00 Q
22937605 -rwxr-xr-x 0 0 328032 31-Oct-1980 00:00 Y
23461893 -rwxr-xr-x 0 0 328040 7-Nov-1980 00:00 a
23986181 -rwxr-xr-x 0 0 328048 15-Nov-1980 00:00 i
24510469 -rwxr-xr-x 0 0 328056 23-Nov-1980 00:00 q
0 -rwxr-xr-x 0 0 0 1-Jan-1980 00:00 y
fat32_boot_sector
Boot sector
Bad
Backup boot sector
Bad
First sectors (Boot code and partition information) are not identical.
A valid FAT Boot sector must be present in order to access
any data; even if the partition is not bootable.
Here are some screens from various diagnostic softwares:
+ DMDE 2.0.1 log file with sectors 0-100:
SUMMARY:
HDD detected by BIOS propertly. HDD detected by WXP as one having RAW filesystem(was FAT32). Everything else fails.
 Post subject: Re: Quantum Fireball lct (20GB, FAT32) DOWN!!!
PostPosted: February 12th, 2010, 11:01
Heres is that 0-100 sector bin file for DMDE which couldnt be attached to previous post due to unknown reasons. :mrgreen:
http://jump.fm/YJPPW
or
http://www.2shared.com/file/11329910/ac ... 0_101.html
(yeah, i cant attach anything via forum tools)
PostPosted: February 12th, 2010, 15:51
The only thing I would know how to do is analyze it in winhex. First compare sector 63 with sector 69. If they are different, copy sector 63 to an empty sector like 62 just to back up sector 63. Then copy sector 69 into sector 63 and see if that fixes it. If not, there are a lot of other things to look for. The main partition may not start at the beginning of the drive but it is pretty easy to find it if it doesn't. Partition table could also be wrong or you may have gotten a bad image. Post results.
PostPosted: February 12th, 2010, 16:40
Sectors 63 and 69 are slightly different. I dont even know how to use winhex that well but i can spot differences without using copare tool. Im not into writing anything on my HDD without making 100% restorable copy and to be honest im not sure what kind of software should i use to make that copy. I got free space on my other Hard Disks, there should be no problem with that. In fact i got strange feeling, that HDD had 255 heads shown in Testdisk, and Testdisk changed it into 240! Well, at least i guess so. Partition table: Yeah, i have tried to fix that but i couldnt. I had that software called PPTD Demo with fixboot utility, but fixboot failed in both modes. Testdisk wants to fix BS, but auto mode aint working and im not sure how to use manual mode. Lets just say that Testdisk is posting so many files, that manual searching for boot.ini would take few hours at best. Possibly more, and theres still no guarantee that it would find anything at all.
Also i am looking for some FREE software which will be able to restre my files. It must be WXP, and it must have GUI application. I have tried ZAR Demo, and its really cool - detects all files and such, but as its just demo i can only copy 4 subfolders with contents. And i need to copy much more than that.
PostPosted: February 12th, 2010, 17:54
Hi Zombie,
You MUST make a clone copy of the fireball drive and then work on the copy!
You want free tools so I suggest you use copyr.dma which works in dos to make the clone copy. Then you can mount the cloned copy in any windows pc and run any recovery software you fancy.
Good luck!
Users browsing this forum: Majestic-12 [Bot] and 232 guests
