 Post subject: please insert drive
PostPosted: February 8th, 2010, 23:28
can someone help me on how to fix my problem??
my trancend 1gb flash drive says that "please insert drive" in my computer when you double click the drive..
my flash drive can detect my windows but you cannot open it..
pls help.. thanks..
 Post subject: Re: please insert drive
PostPosted: February 9th, 2010, 5:36
Maybe try to right click on this drive and go into explorer. Copy all your files off the drive if you can open it up. Then reformat your drive. I see this here a lot with flash drives and normally you can open them up in explore if you can not by double clicking on them. Try this one first.
Iorana Haraharaini
PostPosted: February 9th, 2010, 23:00
doesnt work at all.. =(
any suggestions would be appreciated..
thanks..
PostPosted: February 12th, 2010, 6:16
Check it with CHipGenius (VID and PID id are important), then go to flashboot.ru and find software for your drive.
data recovery Poland
PostPosted: February 12th, 2010, 6:22
that problem at your hardware flashdisk
PostPosted: February 12th, 2010, 20:24
i can't understand the language in flashboot.ru.. =(
how can i get the software for my flash drive??
please help.. thanks..
PostPosted: February 13th, 2010, 1:46
use a translator , language is russian .
PostPosted: February 13th, 2010, 5:08
how can i do that??
PostPosted: February 13th, 2010, 5:15
Anybody have a spoon? :lol:
PostPosted: February 14th, 2010, 2:13
http://translate.google.com.pk/?hl=en&tab=wT
PostPosted: February 14th, 2010, 20:14
got b4 you post the link.. anyway thanks.. =)
PostPosted: March 29th, 2010, 9:05
First of all you can go the run command and type command prompt and through in command prompt you can open your flash drive and then you can copy of your flash drive data easily and then you can format your flash drive.
m3i zero
Users browsing this forum: No registered users and 94 guests
