 Post subject: WANTED PCA FOR WD800JD - 00LUA0; PCB 2060-701335-003 REV B
PostPosted: February 12th, 2010, 13:59
OR SAME HARD DRIVE OR ANY OTHER CAPABLE PCB
Paying by paypal :)
 Post subject: Re: WANTED PCA FOR WD800JD - 00LUA0; PCB 2060-701335-003 REV B
PostPosted: February 13th, 2010, 1:36
hi,
i have this PCB for sell. please contact me by email. thanks.
data recovery service[/b]
PostPosted: February 13th, 2010, 3:08
We have this working PCB in stock, pls contact my hotmail to see if I can help.
Eric
Providing HDD PCBs and donor HDDs, Real in stock.
eric_lee8341@hotmail.com
WhatsApp: +8613480790845
PostPosted: February 21st, 2010, 14:39
Hi anyone else have it?
PostPosted: February 21st, 2010, 21:17
What's wrong with the original?
Can you upload a detailed photo of the component side?
PostPosted: February 22nd, 2010, 7:26
Hello
I have 2 of this pcbs
2060-701335-003 REV B - just pcb 60$
and
2060-701335-003 REV A - the drive 80$
If you need one of this you can contact me.
PostPosted: February 22nd, 2010, 10:11
just no HD in bois, no strange noises ,probably PCB dead
i will buy HD for 60$ thanks
just need to get cheap pcb, to take out some data and then i goes to trash
PostPosted: February 22nd, 2010, 14:51
The PCB contains calibration data that are specific to your drive. You will be lucky if a direct PCB swap works. You will most likely need to transplant the serial EEPROM chip from patient to donor. Some boards have the data inside the main MCU. In these cases a DIY job is unfeasible.
The rule of thumb appears to be that, if a drive spins up but is not detected, or if it tries to spin up, then the board is probably OK. Instead the problem is most likely with the head/disc assembly (HDA). If, OTOH, the drive makes no noise at all, and does not attempt to spin up, then the board is probably faulty.
PostPosted: February 22nd, 2010, 18:18
Thanks for advice, i still want to try :)
PostPosted: January 19th, 2020, 8:08
tcolaco wrote:
Hello
and
Users browsing this forum: No registered users and 83 guests
