 Post subject: Seagate Barracuda 7200.11 ST3500820AS Not working
PostPosted: February 24th, 2010, 17:53
I am in need of expert advice and help. The hard drive is a
Seagate Barracuda 7200.11 500GB ST3500820AS P/N 9BX134-568 Firmware SD81
I have a sound file so you can hear the sound that it makes, and I have 2 pics I made from using
Victoria for Windows 4.3
Can anyone diagnose and tell me what the problem is and how to fix it. I don't have $400-$2400 to pay the experts cause i'm unemployed and that was the amount giving to me when I called a data recover center in my area. Wow that's pricey. Actually I'm a stay at home dad taking care of the baby girl and my wife so desperately wants me to recover this data to get the hospital pics and movies back of the baby. If anyone can help me I have no problem paying for it. We just don't have enough money to fork out $1,000/ A Grand to get the data back cause were not rich. Thanks
Disk Drive Hum.rar [230.56 KiB]
Downloaded 507 times
File comment: seagate pic
File comment: I did 2 pics one of a working maxtor
and one of the seagate and of course the sound file
 Post subject: Re: Seagate Barracuda 7200.11 ST3500820AS Not working
PostPosted: February 24th, 2010, 18:59
I could EASILY be wrong, and and unable to listen to the audio, but based on what I see in the pictures I'm thinking you might need to check this out:
tutorial-resolve-lba-seagate-7200-bios-don-recognize-t11040.html
PostPosted: February 24th, 2010, 19:14
If you want any chance of getting your data back you need to send to a pro. This does not sound like a firmware fault. The only advice i can give is keep the drive safe in a draw and save for professional help. You can easily loose your data for good attempting d.i.y.
PostPosted: February 24th, 2010, 19:44
Eventually I'll get one right :D
PostPosted: February 25th, 2010, 4:04
That drive is seized (or possibly stiction, 5% chance), it's NOT a firmware or PCB issue.
Unfortunately (for you) this is a PRO ONLY case, you are not going be able to "DIY" this one no matter how much guidance, sorry.
PostPosted: February 25th, 2010, 11:59
I was just able to hear the audio, if I could delete my post original post I would, pcimage is 100% correct. This is the other issue the new Seagates are famous for, we get a TON of them
PostPosted: February 25th, 2010, 15:50
Victoria is showing the model number, firmware version (SD81), and serial number (9QM4321W). Is this information stored in the serial EEPROM or on the platters?
PostPosted: February 25th, 2010, 15:57
As the platters are not spinning / accessible, I would assume on the PCB / EEPROM
PostPosted: February 25th, 2010, 16:20
That's the obvious conclusion but AIUI drives report some other generic model number and serial number if they can't access the platters. Furthermore, stiction faults or spindle seizures cause the drive not to report anything at all, or am I mistaken?
PostPosted: February 25th, 2010, 16:25
It varies
PostPosted: February 25th, 2010, 17:19
7200.11 and other F3 architecture drives store the serial number in the ROM, like Toshiba.
This can be proven by connecting the PCB alone and getting an ID.
PostPosted: February 25th, 2010, 20:09
Yes, seized spindle drives can ID via PCB!! Some of them even show you 0LBA with all proper identification, making average computer user believe the FW Bug.
PostPosted: February 25th, 2010, 20:45
make sure it's seized. and don't try to done by self.
data recovery service[/b]
Users browsing this forum: No registered users and 38 guests
