 Post subject: WD2500AAJS-00RYA0 dead preamp need donor
PostPosted: March 4th, 2010, 1:22
Hi guys
I have a WD2500AAJS-00RYA0 with dead preamp,the is headmap 0 2 3
Power on...head does not move/calibrate and shutdown. PCB is tested ok.
Anyone got this drive for sale?
thanks
 Post subject: Re: WD2500AAJS-00RYA0 dead preamp need donor
PostPosted: March 4th, 2010, 5:03
looking for same model & headmap? have you try bigger drive instead of before?
data recovery service[/b]
PostPosted: March 4th, 2010, 6:59
Hi TerraNova,
Did you open it and see if the heads are not stuck in the parkzone ? had one case like this last week.
ZeBong
" Россия еще раз"
PostPosted: March 4th, 2010, 17:33
You might be better off looking for a 320Gb model, then you haven't got the risk of the donor having a different head map.
PostPosted: March 4th, 2010, 20:48
agreed.
PostPosted: March 4th, 2010, 21:43
Ok donor same family 320G, headmap 0 1 2 3 but still wont work.
PostPosted: March 4th, 2010, 21:54
you search donor need to match with family only?
Users browsing this forum: Google [Bot] and 248 guests
