 Post subject: Diagnosis? Barracuda 7200.8 ST3300831A not detected by BIOS
PostPosted: March 9th, 2010, 9:24
Dear all,
Got a strange situation here: After powering down my computer yesterday, the HDD is not detected by the BIOS any longer.
Also, no success on different computers and with external cases.
Terminal output on "regular" power-up (i.e., no business cards etc. were used):
Interface task reset
4096k x 16 buffer detected
TONKA - 1_Disk S.00 01-27-05 12:46
Buzz -
Specs:
Barracuda 7200.8
ST3300831A
P/N 9Y7284-501
Firmware 3.01
Date Code 05406
Site Code WU
PCB sticker 100335769
large chip ST E 100356070
B4387A2
VQ443JTG
AA2AH
TWN 99 510
second largest chip SAMSUNG 510
K4S641632H-UC60
S6416 ZHM600GFV
Any help on error diagnosis???
Thank you very much,
Chris
 Post subject: Re: Diagnosis? Barracuda 7200.8 ST3300831A not detected by BIOS
PostPosted: March 9th, 2010, 9:40
update:
Terminal output on power-up with drive contacts covered (i.e., business card used to cover contacts near P-ATA connectors):
Preamp ID 00 unsupported
Buzz - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Head Mask FFFF - Error Reading Boot Adaptives
Then, the spindle powers down automatically...
PostPosted: March 9th, 2010, 9:43
Heads are dead.
www.datarecoveryne.com
PostPosted: March 9th, 2010, 10:42
[quote="ranti"]update:
[quote]
You should let the pcb as is it, don't put anything between contacts and post terminal log here....
Rgds
www.datasave.ro
PostPosted: March 9th, 2010, 10:58
Terminal output after "regular" power-up (as in my first post):
Buzz -
nothing else for ~10min...
Cheers,
Chris
PostPosted: March 9th, 2010, 11:41
Ok...Now I see it....
Try CTRL+Z and see if it responds in terminal.
Rgds
www.datasave.ro
PostPosted: March 9th, 2010, 13:28
No, doesn't seem to do anything... But let me double-check my TX-Connection...
C.
PostPosted: March 10th, 2010, 4:46
... which seems to be working ok... Any hints how to fix this? Is there a chance to swap the PCB? Any sources?
Thanks,
Chris
PostPosted: March 10th, 2010, 5:00
harddrivespecialist wrote:
Heads are dead.
I agree
PostPosted: March 10th, 2010, 5:32
Thanks for your help, guys...
In that case: no chance of swapping the PCB, I guess...
One more thing: The disk sounds like it doesn't release the heads from their parking position (no clicking noise whatsoever). Could any of you guys point me to the right access seal (which seal to remove? -> see attached photo)?
I could then try to release the heads manually under a laminar flow box (don't have a real clean room environment in my living room ;-) )? See any chances?
Cheers,
Chris
PostPosted: March 10th, 2010, 5:40
Its your hard disk, and your data, so its your call. But I strongly advise you read the sticky about DIY Data recovery first, and also evaluate the value of the data.
There really are so many factors to consider when opening a hard disk, and if data is invaluable to you then at this point you should make a decision as to whether you can live without it should anything go wrong...
PostPosted: March 10th, 2010, 5:50
Hi
If u r Data is not important play with this if important send it to Pro.
PostPosted: March 10th, 2010, 5:54
Duplicated post please remove - sorry for inconvenience.
PostPosted: March 10th, 2010, 5:56
PostPosted: March 10th, 2010, 5:57
It's obvious data is NOT important, or is it worth a trial-and-error at risk of making everything unrecoverable ?!?
PostPosted: March 12th, 2010, 12:22
Dear all,
after doing a little more research, I found out that two of the chips (largest chip: 100356070 and third largest chip: 100317176) on the PCB are getting REALLY HOT after few seconds of operation... Therefore I decided to give it a shot with a new PCB nevertheless before trying to open the disk...
--> pcb-wanted-barracuda-7200-st3300831a-t15109.html
Thanks for your help and advice.
Cheers,
Chris
Users browsing this forum: Google [Bot] and 54 guests
