 Post subject: HSA compatability for Swap: WD1600AAJS
PostPosted: March 9th, 2010, 16:44
I think it should be fine, but I normally try to get a better match (5th digit also). Donor on right.
What do you think?
THANKS!
 Post subject: Re: HSA compatability for Swap: WD1600AAJS
PostPosted: March 10th, 2010, 2:54
Hello mediaman,
I think that the left one PCB : xxx 1590 xxx
and the right one PCB : 1552 or 1537 I can't remember excatly
head swap will not work on two different drives.
PostPosted: March 10th, 2010, 4:56
I do not think the DCM code has any relevance on the ROYL drives. I think more important is head map match and family match.
PostPosted: March 10th, 2010, 4:58
@ hddguy,
Agree.
PostPosted: March 10th, 2010, 9:19
I appreciate the feedback.
Unknown: I will look at the PCB's later when I get to the lab.
Any tips for correct donor matching on these drives? I was sure, and have had success before with 5 and 6 DCM digits (on smaller WD's), but i have also always looked for a better match in other areas (date, -00xxxx etc)
Thanks again for your patience and help.
PostPosted: March 11th, 2010, 17:15
Uknown,
Here are the two PCB's, you are very right about differences.
Any tips on HSA matching criteria for donor?
PostPosted: March 14th, 2010, 7:06
Head map match and family match that's all, like Mr.Hddguy said.
Users browsing this forum: Google [Bot] and 79 guests
