 Post subject: WD2500KS-00MJB0 DCM: HSBHNTJAHN LBA: 488397168 Help
PostPosted: March 13th, 2010, 1:19
Power supply went out so I replaced it. I hooked two pwrs to my HDD. It screamed. Had to replace it, but need the data off the old HDD. Still have old one but is not recognized. The board gets very warm with no spin. Bought a logic board for same model but different DCM it spins and does not get warm and is still not recognized by my computer. It states something like insert system disk when I try to boot up. I have been told to replace the BIOS chip in the board with the old one. Where is the BIOS chip on the WD2500KS Logic board and is it replaceable by a not so hot computer savy individual?
It is a WD2500KS-00mjb0 WD Caviar SE16 27 Dec 2007
DCM HSBHNTJAHN LBA: 488397168 SN: WCANKM409795
And of course any other info would be appreciated.
A newbie to the forum and thanks in advance! ! ! ! !
 Post subject: Re: WD2500KS-00MJB0 DCM: HSBHNTJAHN LBA: 488397168 Help
PostPosted: March 13th, 2010, 9:34
All you can do is to swap the PCB with a compatible one and swap U12 if the PCB has it installed.
If not, there is no other easy option, u'd better take the drive for professional recovery before you screw it up more.
There are some topics on board replacements, check those first.
PostPosted: March 13th, 2010, 16:11
What is in the U12 spot?
PostPosted: March 13th, 2010, 18:18
Flash
PostPosted: March 14th, 2010, 18:02
I am not much of a computer wiz so is the flash the same as the BIOS chip or something different.
I appreciate your info. Thanks!
PostPosted: March 14th, 2010, 21:52
If you are not sure, please be careful. You can kill that chip in just a few seconds if you mishandle it. I sent you what you were asking via PM.
PostPosted: March 15th, 2010, 6:44
If any Important Data is in give Drive to Pro. if not try to swap U12 small firmware chip u can find Picture in previous blocks.
PostPosted: March 15th, 2010, 7:37
send pic from your PCB!
NS DATA RECOVERY
www.nsrecovery.ir
PostPosted: March 15th, 2010, 9:00
check PM please. hope can help you solve it out.
data recovery service[/b]
Users browsing this forum: No registered users and 52 guests
