 Post subject: cannot initialize new HD
PostPosted: March 24th, 2010, 20:06
I just received my new drive (western digital caviar green 1.5 TB) but can't initialize. The disk appears in the Device Manager and Disk Management. But when I want to initialize it, it gives an error message of either The Device is Not Ready or Incorrect Function.
Please advice.
Thanks.
 Post subject: Re: cannot initialize new HD
PostPosted: March 24th, 2010, 20:21
sounds like you got a possible faulty drive as it wont initialize
but need more information first
like what type of os are you using windows 7
how many drives connected up to your computer to begin with.
is this a sata drive or ide drive
PostPosted: March 24th, 2010, 20:24
yes Windows 7 Pro 64bit, SATA drive.
Enclosure is by Infosafe
I've tried with 2 laptops..
PostPosted: March 24th, 2010, 20:30
possible the enclosure is at fault as you can buy cheap ones and good ones
PostPosted: March 24th, 2010, 20:35
http://www.startech.com/item/UNI3510U2E ... h-OTB.aspx
i got this... maybe i shall try with another enclosure..
PostPosted: March 24th, 2010, 20:36
try this
go to start then run
type CMD.EXE (do not hit enter)
Right-click on CMD.EXE in the area above where you typed
Click on "Run as administrator"
You are now at a command prompt
Type following:
1. Diskpart and hit enter
2. List Disk and hit enter
3. Select Disk n where n is the number shown for your problem drive and hit enter
4. Create Partition Primary and hit enter
5. Format fs=ntfs quick and hit enter
6. Assign and hit enter
7. Exit and hit enter
8. Exit and hit enter
Now :
Win key
type DISKMGMT.MSC and hit enter
Does your drive show up at all
PostPosted: March 24th, 2010, 20:39
ok its possible that you got a faulty case or a faulty drive
if you tried it on another machine
can you connect the hard drive up to the motherboard at all
PostPosted: March 24th, 2010, 20:48
DISKPART> Select Disk 1
Disk 1 is now the selected disk.
DISKPART> Create Partition Primary
DiskPart has encountered an error: The device is not ready.
See the System Event Log for more information.
PostPosted: March 24th, 2010, 20:50
from Event log:
Log Name: System
Source: Virtual Disk Service
Date: 3/24/2010 8:47:23 PM
Event ID: 10
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: Frozz-PC
Description:
VDS fails to write boot code on a disk during clean operation. Error code: 80070015@02070008
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Virtual Disk Service" />
<EventID Qualifiers="49664">10</EventID>
<Level>2</Level>
<Task>0</Task>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2010-03-25T00:47:23.000000000Z" />
<EventRecordID>129914</EventRecordID>
<Channel>System</Channel>
<Computer>Frozz-PC</Computer>
<Security />
</System>
<EventData>
<Data>80070015@02070008</Data>
</EventData>
</Event>
PostPosted: March 24th, 2010, 20:57
ok what the system event log for say
there something wrong possible with the hard drive case,
not working
or possible the hard drive is faulty.
as your getting the same fault on the other machines
the only way to test it now is by connecting the hard drive up in another case or inside the machine
allso is this a bought version of windows 7 or a copied version ???????
check microsoft website for updates on your hard hardware
PostPosted: March 24th, 2010, 21:03
the code Error code: 80070015@02070008 is hard drive fail
but i think its the hard drive encloser that is at fault and not the drive itself
see if you can change it
PostPosted: March 24th, 2010, 22:52
yes it's the enclosure!!
thx Craig! :D
PostPosted: March 26th, 2010, 2:17
no problem glad to help you out :D
Users browsing this forum: Google [Bot] and 51 guests
