 Post subject: Clicking HDT721010SLA360, solution?
PostPosted: March 25th, 2010, 3:23
Hello all
I have a HITACHI HDT721010SLA360 which makes clicking noise.
Situation is below.
1. Platters didn't rotate.(Heads is stuck on the platters, I saw in the clean bench.)
2. Remove the heads from the platter.
3. The drive spins up fine, but it makes clicking noise.
4. I thought that there was a cause to a heads mulfunction, and changed a MHA (same model, same MLC, right???)
5. Drive still clicking. (And I replaced MHA from the recipient to the donner again, it works.)
So, I guess the problem is a platter...??? any ideas or solution?
Thanks alot.
atmosphere
 Post subject: Re: Clicking HDT721010SLA360, solution?
PostPosted: March 25th, 2010, 3:45
everything is original? and patient drive haven't open before? will know more after check head.
data recovery service[/b]
PostPosted: March 25th, 2010, 4:07
Thank you for a reply.
Yes. Everything is original. It has not been opened so far.
And, how do I check heads? use the microscope?
Thanks.
atmosphere
PostPosted: March 25th, 2010, 4:54
I thought that there was a cause to a heads mulfunction, and changed a MHA.
has it been opened or not ?
PostPosted: March 25th, 2010, 5:13
sorry, i opened the patient disk. and it was not opened out till then.
PostPosted: March 25th, 2010, 14:28
did you try changing pcb ?
Users browsing this forum: Bing [Bot] and 89 guests
