 Post subject: Quick question on finding donor drive for fujitsu
PostPosted: March 25th, 2010, 11:17
I read from the article on finding a donor drive that I should:
First character in firmware revision (xx-Xxxx) should match
For FUJITSU drives
Now, I am not entirely sure why the 3rd X is capitalized (is that the first character that I should be looking at?)
Also, I am not sure where to find the firmware revision on my hard disk:
http://tinypic.com/r/j8fgvl/5
The one on the article said that is should be in the format xx-xxxx, but I dont see any in that format. I see a "REV" but the string is longer than 2+4 characters.
 Post subject: Re: Quick question on finding donor drive for fujitsu
PostPosted: March 26th, 2010, 4:45
The information you read is too old.
The firmware for Fujitsu is below the REV NO. in the picture xxxxxx - xxxxxxxx
PostPosted: March 26th, 2010, 11:59
so what should I do?
What number should I match it to?
PostPosted: March 26th, 2010, 13:03
What are you trying to accomplish?
PostPosted: March 26th, 2010, 20:26
need head or firmware? seems make it too complex
data recovery service[/b]
PostPosted: March 26th, 2010, 20:54
did anyone notice the apple :shock:
its more likely a headstack problem.
if im correct your have to find the right apple hard drive to match up
not a pc version
which will cost a lot of $$$$$$$$$$
PostPosted: March 26th, 2010, 21:08
Hi what is wrong with your drive, ckicks or hum,,,or just dead?
Bosse
http://www.rescue-it.se
PostPosted: April 11th, 2010, 7:30
not detected by BIOS.
Opened up the drive, SA is scratched. Is this still recoverable?
PostPosted: April 11th, 2010, 7:36
Maybe yes.
PostPosted: April 11th, 2010, 8:15
so should I go ahead and try to find a donor drive? So how do I match the drive? do I really need the same apple drive as one poster suggested?
Users browsing this forum: No registered users and 219 guests
