 Post subject: no /dev/hda in linux
PostPosted: March 27th, 2010, 6:20
I'm trying to recover my Western Digtal 500GB hd (connected through IDE), I've already succesfully recoverd 80GB with copyr.dma (didn't have a bigger IDE drive laying around).
and want to do the rest of the drive with GNU ddrescue.
I use the Parted Magic live cd to do this.
The problem is that it can't find my HD, although it is listed when I look in the Hardware info app.
How can I mount it as /dev/hda or /dev/sda or whatever might work?
Thanks.
(Programs like Copyr.dma, Mediatools, hdclone all recognize the drive, but not parted magic linux.)
 Post subject: Re: no /dev/hda in linux
PostPosted: March 27th, 2010, 9:25
This question would get a better answer on a linux forum. This is a very simple task with unix and achievable with only a few terminal commands.
Zero Alpha: zeroalpha.com.au
PostPosted: March 27th, 2010, 19:11
Would you like to share it?
PostPosted: March 27th, 2010, 21:39
Just google mount and dd for linux and you will find tutorials.
PostPosted: March 29th, 2010, 10:05
Just for the people who may encounter the same problems.
When I use the Ultimate Debian Live CD from multidistro.com, which has ddrescue preinstalled btw, I'm able to access my HD on /dev/hda and run ddrescue on it.
