 Post subject: Strange ST3160813AS
PostPosted: June 22nd, 2009, 5:38
The drive is not recognized by BIOS (BUSY all the time), but the strange thing is that it does not show up in the terminal . Sometimes only a letter p appears and that is all.
I've got a good 320GB drive of the same family, so I checked the terminal setting - everything is fine. I checked the PCB by swapping the FLASH chips. The PCB is OK.
Any suggestions about the cause of this strange behaviour ?
 Post subject: Re: Strange ST3160813AS
PostPosted: June 22nd, 2009, 6:16
Bad mcu/ram or pcb ko. Check parts.
PostPosted: June 22nd, 2009, 7:33
What stands for "mcu/ram or pcb ko" ? :shock:
The PCB is working fine with the other (320GB) drive.
PostPosted: June 25th, 2009, 3:27
Can you access F> ?
Also did you try the other pcb on "bad" drive?
DataRecovery.bg
PostPosted: June 26th, 2009, 9:29
Samo wrote:
Can you access F> ?
F> is not accessable with and without HDA.
The other pcb behave the same way as the native.
FW : CC2F
PostPosted: July 4th, 2009, 7:44
HI,
My 7200.11 has similar problem either, I can not get access to the HDD through the COM port.
PostPosted: July 6th, 2009, 3:13
fg2000 wrote:
HI,
What is the firmware revision of your drive?
PostPosted: July 6th, 2009, 15:42
BGman wrote:
Samo wrote:
Can you access F> ?
FW : CC2F
If I remember this drive can be short curcuited to force F> access. But you better get one of the Guru's to confirm this.
PostPosted: July 6th, 2009, 15:43
fg2000 wrote:
HI,
Your problem is mostlikley a different one. Do you use any professional tools?
Users browsing this forum: juliansagebiel and 86 guests
