 Post subject: Seagate 500Gb - 7200.12 BSY
PostPosted: February 12th, 2010, 8:08
Hi to all,
Have this disk that the disk clicks, and dont get ID
Change heads with the same P.ID, and the same think happen.
In Terminal i have this :
Rst 0x10M
No HOST FIS-ReadyStatusFlags 2002B001
Press CTR+Z
happen this:
F3 T>
Spinning Down
HighPowerMode
Spin Down Complete
Elapsed Time 0.104 msecs
Delaying 5000 msec
Jumping to Power On Resetý
Rst 0x10M
Anyone have worked with a disk like this,
Thanks in advanced
ZeBong
" Россия еще раз"
 Post subject: Re: Seagate 500Gb - 7200.12 BSY
PostPosted: February 12th, 2010, 21:47
I'm working on one with the same problem right now, having no success other than confirming its behaving just like 7200.11 BSY but that fix does not work. I am trying variants at present. Maybe ACE have some experience? I will email them asking for support. Please post or PM me if you make any headway.
PostPosted: February 13th, 2010, 6:56
is your disk clicking 11 times them stop ?
ZeBong
" Россия еще раз"
PostPosted: February 24th, 2010, 7:05
Sorry head down bum up, missed your reply.
Yes it was. I say was as we pulled the plug, another company told the client they could fix it and we hadn't so I sent it on. I am awaiting their results, but I suspect they will get no further than we did. This seems to be a new firmware bug. Very frustrating and I guess we will see many more of them soon as the .12 is very popular right now.
I'm looking forward to getting another one in with more time available to work it right through, or have someone (ACE?) release an update to PC3000 and the Seagate Family manual, with a fix in tow.
Has anybody else dealt with one of these successfully yet? At least say yes so I know that there is a solution.
PostPosted: August 17th, 2010, 7:15
I also have this problems.
Do you have any solution zebong.
PostPosted: February 14th, 2012, 14:15
Is this firmware issue or engineering defect? I am not been able to fix some of then even in udma. drive simply does not accept commands and stays in loop. Curious to know opinions.
PostPosted: February 14th, 2012, 14:45
zebong wrote:
Hi to all,
Rst 0x10M
Press CTR+Z
happen this:
F3 T>
Spinning Down
HighPowerMode
Spin Down Complete
Delaying 5000 msec
Rst 0x10M
Thanks in advanced
PM Sent...
PostPosted: February 17th, 2012, 9:13
Replied to PM.
PostPosted: May 15th, 2012, 5:58
Hi ALL,
I have the same issue. Could you please tell me how to solve it?
Thank you very much
PostPosted: May 21st, 2012, 3:24
ZeBong
I have the disk which clicks 12 times. Any solution.
PostPosted: May 24th, 2012, 1:45
lohuanming wrote:
Hi ALL,
Thank you very much
Hi, can you load CERT code or App code?
* Có ba thứ ngu dốt :
Không hiểu biết những gì mình đáng biết.
Hiểu biết không rành những gì mình biết.
Hiểu biết những gì mình không cần biết.
PostPosted: May 24th, 2012, 3:41
Sorry , I cannot test as the customer has taken his drive from me.
Thanx for showing interest.
PostPosted: May 30th, 2012, 9:48
Did you try a hot swap?
PostPosted: May 30th, 2012, 13:28
If it is spinning down, it is almost always heads.
PostPosted: May 31st, 2012, 3:21
No , Donor was not available at that time.
PostPosted: June 1st, 2012, 11:10
agree
PostPosted: June 4th, 2012, 14:22
yes i have same problem 11 times clicking and then stops;
Model : ST9320325AS
Serial : 5VD3WT9J
Firmware : 0002
Capacity : MB ()
LED:000000CC FAddr:00259965
error
tried hdd lock soln and capacity 0 soln
but not worked.what might be issue?
PostPosted: June 5th, 2012, 7:41
Bad heads, for example.
LED CC is a symptom not the cause.
PostPosted: June 5th, 2012, 8:13
Thanks for you reply
PostPosted: June 7th, 2012, 11:00
Same problem. How did you solve it? Thanks :)
