Forum rules
 Post subject: Samsung HS212UHE connectivity - Apple Macbook Air
PostPosted: September 15th, 2010, 10:45
Do you know if it's exist adapter sata or ide for the HDD Samsung HS212UHE ?
This isn't ZIF connectivity. We havn't find a compatible adapter to SATA or IDE.
Model : HS12UHE
HDD P/N : HS12UHE/A
REV.A
 Post subject: Re: Samsung HS212UHE connectivity - Apple Macbook Air
PostPosted: September 15th, 2010, 11:35
i think its 1.8"
PostPosted: September 16th, 2010, 2:48
Yes, the HDD is 1,8'' but the connectivity isn't ZIF but other thing.
Do you know a reference of adapter for it ?
PostPosted: September 16th, 2010, 3:17
well am looking, it is N3U 1.8"
am searching also for the converter, will let u know when i found something
btw, did u take the HDD from a MAC PC (Apple) i think they are the one who always come with stupid (smart) i dono idea`s?
PostPosted: September 16th, 2010, 3:24
could you please provide some images for the Interface
specially the ribbon
and the pcb if possible
thnx
PostPosted: September 16th, 2010, 4:30
finally, i guess it is ZIF3
check those links on ebay
http://cgi.ebay.com.my/1-8-PATA-ZIF-HDD ... 53dcd99093
http://cgi.ebay.com.my/1-8-Toshiba-PATA ... 53dd097bf4
http://cgi.ebay.com.my/1-8-PATA-ZIF-CE- ... 3ef890c06b
am ordering for me those
good luck
PostPosted: September 16th, 2010, 5:37
Thank you for your answer einstein9 but check the number of the pin on my picture and on your ebay auction.
This is not the same. See my new picture. On the left, this is a ZIF adapter to PATA, in the middle, a compatible cable for my HDD and on the right, this is my HDD.
PostPosted: September 16th, 2010, 6:28
thats why i asked about closer image
so this doesn`t work
PostPosted: September 16th, 2010, 10:35
No other idea ?
PostPosted: September 16th, 2010, 10:42
my brain is processing looking for alternatives :idea:
guess am the only one thinking about this, doesn`t matter, soon or later will come
PostPosted: September 16th, 2010, 13:06
yan1982, can you upload closer very close image of the ribbon i wanna see the pins how many if possible
many thnx
PostPosted: September 17th, 2010, 7:39
Hi
If these are from MacBook air and is the samsung drive these drives are actually a sat drive
You will require a sata to zif adaptor
I am currently trying to source some but have had no luck
They are quite rare these drives which is making it difficult to obtain
I did find an article on how to build an adaptor but don't have the link with me
However if you google the model of the drive, Mac book air and sata adaptor you should find the link
I will try and post it in the next few days
If you make progress please let me know
PostPosted: October 18th, 2010, 11:13
Hi
We just had one of these nightmare drives.
It's a LIF-connector - not a ZIF - It only has 24 ribbons in the cable. But it’s just a SATA connector wired differently (and some power /ground) … at least that’s what I could get out of google and http://forums.macrumors.com/showthread.php?t=657341
(Been told there exist a small-LIF as well with an even smaller FCC-ribbon).
We haven't been able to find an adapter to SATA - but there is an usb adapter, (thank you to the guys at Data Clinic)
http://www.mydigitaldiscount.com/SPD/runcore-1-8--sata-lif-usb-2-0-hdd-ssd-enclosure--80000D7A-1270043844.jsp
But then again... a usb connection is far from optimal, if there is some kind of damage - guessing you can grab the SATA data stream from within the usb-adapter - if you do find a way... please upload the schematics;)
Best of luck
Michael, PAD-dataservice
PAD-dataservice
http://www.pad-dataservice.dk
PostPosted: October 18th, 2010, 17:46
PAD-dataservice wrote:
... guessing you can grab the SATA data stream from within the usb-adapter - if you do find a way... please upload the schematics;)
SATA requires 2x TX and 2x RX wires, plus ground.
If you can upload a detailed view of both sides of the PCB, then it should be very easy to identify the signal pairs.
