I just recently got a bunch of HC550 18TB non-sed 512e/4k SATA drives. I wanted to convert these to 4k/4k for use in ceph. So I went on my merry way and downloaded hugo and did;
./hugo f -b 4096 -m WUH721818ALE6L4
Now this turned out to be a bit of a mistake as it started formatting all 12 drives in the server in question. Which initially was fine, but the format took forever, and unfortunately I lost ssh connection to the server and hugo subsequently crashed. Only later I learned I should have used --fastformat.
A good 24hr later, I powercycled the server. And now, unfortunately none of the disks seem to work anymore. I can still see then with hugo s:
# ./hugo s
Manuf. Model Serial Interface Capacity Type Firmware
1) Seagate ST9146853SS 6XM1C4EM SAS 146 GB HDD YS0D
2) Seagate ST9146853SS 6XM26BYY SAS 146 GB HDD YS0C
3) HGST WUH721818ALE6L4 3RG72Y4A SATA 18000 GB HDD PCGAW232
4) HGST WUH721818ALE6L4 3RG6X5BA SATA 18000 GB HDD PCGAW232
5) HGST WUH721818ALE6L4 3RG6HYBA SATA 18000 GB HDD PCGAW232
6) HGST WUH721818ALE6L4 3FG8DL1T SATA 18000 GB HDD PCGAW232
7) HGST WUH721818ALE6L4 3RG71YWA SATA 18000 GB HDD PCGAW232
8) HGST WUH721818ALE6L4 3RG6EYTA SATA 18000 GB HDD PCGAW232
9) HGST WUH721818ALE6L4 3RG5Z48A SATA 18000 GB HDD PCGAW232
10) HGST WUH721818ALE6L4 3FG7X4TT SATA 18000 GB HDD PCGAW232
11) HGST WUH721818ALE6L4 3RG7D82A SATA 18000 GB HDD PCGAW232
12) HGST WUH721818ALE6L4 3RG6H6NA SATA 18000 GB HDD PCGAW232
13) HGST WUH721818ALE6L4 3RG742ZA SATA 18000 GB HDD PCGAW232
14) HGST WUH721818ALE6L4 3RG71UXA SATA 18000 GB HDD PCGAW232
But they are unresponsive in regards to formatting them, and if the MegaRAID controller tries to configure them as non-raid devices, they are immediately marked as failed until reboot.
Trying to format one yields the following result:
# ./hugo f -b 4096 --fastformat --danger-zone -s 3RG71UXA
Format device on 1 Device(s)...
Failed: Format command Failed on device 3RG71UXA.
Device will not be formatted.
Any advice at all would be greatly apprechiated.
Thanks!
Best,
Rune
