 Post subject: st1000lm024
PostPosted: May 26th, 2016, 13:19
Hi
Hard drive is
model: ST1000LM024
part: HN-M101MBB/EX2
Laptop HDD led showed constant activity, rebooted successfully but then froze. HDD is now not recognized at all by computer, won't show in bios.
plugged in as a slave dmesg reports:
[197281.097439] ata4: exception Emask 0x10 SAct 0x0 SErr 0x4050000 action 0xe frozen
[197281.097443] ata4: irq_stat 0x00000040, connection status changed
[197281.097445] ata4: SError: { PHYRdyChg CommWake DevExch }
[197281.097450] ata4: hard resetting link
[197286.869631] ata4: link is slow to respond, please be patient (ready=0)
[197291.102566] ata4: COMRESET failed (errno=-16)
[197291.102571] ata4: hard resetting link
[197296.875472] ata4: link is slow to respond, please be patient (ready=0)
[197301.108422] ata4: COMRESET failed (errno=-16)
[197301.108429] ata4: hard resetting link
[197306.881337] ata4: link is slow to respond, please be patient (ready=0)
The drive sounds as though spinning up and clicks as though heads moving i think but i am not an expert.
There is no timeout, the drive does not give up or spin down or stop clicking until unplugged.
I have a very similar donor drive available with matching part numbers etc.
What is the likely cause of fault? heads/preamp or possibly PCB? i would expect the drive to spindown and not stop responding/freezing if just a head issue, is that possible?
I have read about a serial adapter to read diagnostic information, does this work on my drive and is there a schematic anywhere for this? would it help diagnose my issue?
can pcb be swapped on this model? is rom transplant necessary?
The lost information is not worth the cost of professional recovery to me but i am interested in trying anyway.
I have not opened the cover yet but i have use of a cleanroom if head surgery is necessary. other than that i have no specialist recovery tools.
Side question: I have read about connecting a working drive then suspending and swapping the pcb to a bad drive to recover data. in what situation does this work but swapping the pcb normally not work? why does it have to be connected then suspended? when there is a problem with the system area of the platter is this correct?
thanks in advance.
 Post subject: Re: st1000lm024
PostPosted: May 26th, 2016, 15:19
If it's clicking it will be a head issue, not DIY.
Contact Andy at Databusters in Glasgow, pro recovery might not be as expensive as you think!!
PostPosted: May 26th, 2016, 16:38
How to connect a terminal cable on a Samsung drive ?
http://www.hddoracle.com/viewtopic.php? ... 189&p=2786
PostPosted: May 26th, 2016, 17:22
ActiveFW : 00
               FWVer : 0001
                           SATA PLL cal done
                                            DDR size detected = 16MB
        *PAUNI_L2958*PA VID=0011 PN=000D Rev=0001- PA_LSI2958 Found
        *PAUNI_L2958*PA VID=0011 U
S_0SO_1
SPU@22'C,5049mV
IS=1
CLA ..36/78
HO..OK
HO RPM=692 OK
AC 1295
ST..Skip..OK
mS1 00000003
GT:412
SC(L):4105/58
BE.N:27
LD..OK
UF 3 1stGrayErr Hd:0
UD..OK : 58
PK_3   C:523476 H:0
GT:413
SC(L):4105/44
BE.N:29
LD..OK
SK C:  7764 H:1
S_0SR:0
AP:1 C:  7764->  7285 H:1->0 AP Cnt: 0
UF4 1VE
UF 3 1stGrayErr Hd:1
SK C: 26781 H:2
SR:1
AP:1 C: 26781->  7285 H:0->0 AP Cnt: 0
UF4 1VE
SK C: 27523 H:2
SR:2
AP:1 C: 27523->  7285 H:0->0 AP Cnt: 0
UF4 1VE
SK C: 28813 H:2
SR:3
AP:1 C: 28813->  7285 H:0->0 AP Cnt: 0
UD..OK : 44
PK_1   C:   572 H:0
GT:414
SC(L):4105/24
BE.N:27
LD..OK
UD..OK : 24
PK_3   C:524138 H:0
GT:414
SC(L):4108/53
BE.N:26
LD..OK
SK C:  7553 H:1
AP:1 C:  7553->  7285 H:0->0 AP Cnt: 1
UF4 1VE
SK C: 26473 H:2
S_0SR:0
AP:1 C: 26473->  7285 H:0->0 AP Cnt: 1
UF6 GE
SK C: 40595 H:2
SR:1
AP:1 C: 40595->  7285 H:0->0 AP Cnt: 1
UF4 1VE
SK C: 39838 H:2
SR:2
AP:1 C: 39838->  7285 H:0->0 AP Cnt: 1
SK C: 39400 H:2
SR:3
AP:1 C: 39400->  7285 H:0->0 AP Cnt: 1
UD..OK : 53
PK_1   C:   239 H:0
GT:414
SC(L):4108/58
BE.N:30
LD..OK
UD..OK : 58
PK_3   C:524233 H:0
GT:415
SC(L):4110/41
BE.N:29
LD..OK
SK C:  7899 H:1
AP:1 C:  7899->  7285 H:0->0 AP Cnt: 2
UF6 GE
SK C: 27271 H:2
S_2 00000007 0000017C 00000007 00000000SR:0
AP:2 C: 27271->  7285 H:0->0 AP Cnt: 2
UF6 GE
SK C: 36661 H:2
SR:1
AP:1 C: 36661->  7285 H:0->0 AP Cnt: 2
UF4 1VE
SK C: 36782 H:2
SR:2
AP:1 C: 36782->  7285 H:0->0 AP Cnt: 2
UF6 GE
SK C: 62467 H:2
SR:3
AP:1 C: 62467->  7285 H:0->0 AP Cnt: 2
UD..OK : 41
PK_1   C:523485 H:0
GT:415
SC(L):4106/35
BE.N:30
LD..OK
UF4 1VE
SK C:  3687 H:2
AP:1 C:  3687->  7285 H:0->0 AP Cnt: 3
UF6 GE
SK C: 27717 H:2
S_0SR:0
AP:1 C: 27717->  7285 H:0->0 AP Cnt: 3
UF4 1VE
SK C: 28755 H:2
SR:1
AP:1 C: 28755->  7285 H:0->0 AP Cnt: 3
UF6 GE
SK C: 29058 H:2
SR:2
AP:1 C: 29058->  7285 H:0->0 AP Cnt: 3
UF6 GE
SK C: 32052 H:2
SR:3
AP:1 C: 32052->  7285 H:0->0 AP Cnt: 3
UD..OK : 35
PK_1   C:524252 H:0
GT:415
SC(L):4095/37
BE.N:25
LD..OK
UD..OK : 37
PK_3   C:   101 H:0
GT:416
SC(L):4106/44
BE.N:27
LD..OK
SK C:  8003 H:1
AP:1 C:  8003->  7285 H:0->0 AP Cnt: 4
UF6 GE
SK C: 29411 H:2
thanks guys, the cycle repeats with the cnt number increasing.
from looking at other dumps i think you will tell me this confirms a head issue?
is there any explanation of the output, out of interest?
PostPosted: May 26th, 2016, 18:11
yes this is head prb
http://www.hpwlab.com
PostPosted: May 29th, 2016, 12:40
thanks guys,
Head replaced & drive imaged.
few read errors and horrible noises but the report i was after is intact and i can have an easy week instead of writing it up again.
swap took me about two hours, worst part was the head retaining screw underneath, nearly stripped it.
I have a new found respect for what recovery people do.
I used to think i had steady hands now i know better.
going for a lie down. don't worry your jobs are safe, i am never doing that again.
thanks everyone.
PostPosted: May 29th, 2016, 16:24
Congrats!
PostPosted: May 30th, 2016, 6:48
pff wrote:
thanks guys,
thanks everyone.
Good work, glad it went well.
This is were a steady whiskey comes in hand...just kidding :mrgreen:
http://www.rescue-it.se
PostPosted: May 30th, 2016, 6:54
congrartes sir for your success.All other new bies can be happy if you share your success here.Like how you manage donor [selection],any extra work like rom adaptives etc.
all the way congrates again.
PostPosted: May 30th, 2016, 6:55
PostPosted: May 30th, 2016, 9:35
very good , congrates :D :D :yayaya:
PostPosted: July 7th, 2016, 14:35
[quote="pff"]
PostPosted: July 7th, 2016, 14:39
Wrong thread , sorry
Users browsing this forum: No registered users and 109 guests
