 Post subject: How to unlock ST500LT012?
PostPosted: May 30th, 2016, 21:56
Hey guys!
I've some problems with an ATA Locked ST500LT012 i've got from a friend...
Tried with ZOC and Seagate Tool (F3_hpwlab) but didn't success yet
I use a TTL CP2104 [url]http://www.ebay.de/itm/131749981549
[/url]
It's just connected with TX and RX as the Drive is 1,8V powered
(it's possible to get it connected)
With ZOC I always get error Messages (see Log)
With Seagate Tool I don't get password (don't know whicht track to scan for Password) and empty Track Reads
I've give it a new try today but still without success :cry:
Last time I just connected SATA Power, RX and TX from TTL Adapter to the Drive.
Now I also conneted GND from TTL adapter to the Drive...
Maybe this was the reason for SIM and RAW Error last time...
I also tried different buffer settings when i was asked this time - don't know what it is for...
Last time I just did what I've wrote...
I didn't use "m" command or anything else I shouldn't do yet ;)
Just have these Programs from Internet I can work with (Freeware)
Script always stopps with error on line 176 and Bad Buffer Blocks...
[SERIAL/DIRECT] CONNECTED TO PORT COM4 (38400-8N1)
Boot 0x10M
SpinUpTime = 000006B0
TTR1 = 000007F9
(P) SATA Reset
RAW OFF
(DOS) Debug enabled
Intel 6G->3G
Send Status: Phy Ready without COMRESET, Status=50 PASS
TotalSuperBlks 00071C4D TotalValidSuperBlks 00071C4D
RETRY 0B48
   176 +++             TMP=delstr(TMP,1,k-1)
   239 +++          TMP2=TOASCII(i)
   212 +++       call RECEIVE
    50 +++    NXTADDR=GET_DATA(ADDR,DUMPLEN)
Error 40 running "C:\Dokumente und Einstellungen\Administrator\Desktop\CP210x_VCP_Windows\SUnlock.zrx", line 176: Incorrect call to routine
Error 40.13: DELSTR argument 3 must be zero or positive; found "-1"
Boot 0x10M
SpinUpTime = 000006BD
TTR1 = 00000806
(P) SATA Reset
RAW OFF
(DOS) Debug enabled
No Phy: Staggered spin bypass PASS
RETRY 0C41
I added also a detailed Log from ZOC for further research...
ZOC1605_COM401_ZocSupressOutput 0.rar [232.85 KiB]
Downloaded 1007 times
Is there any other special program I could get from anywhere which I could use to unlock???
Please help me to unlock this creepy piece of a Seagate Drive!
read also here for some further Informations and more photos: http://www.hddoracle.com/viewtopic.php?f=2&t=1575&p=8824#p8824
Best regards
Berny_AB
 Post subject: Re: How to unlock ST500LT012?
PostPosted: May 31st, 2016, 2:19
replace 0A30 ==> 1C00 dialogue
the script runs on ST500LT012 I specifically checked.
PostPosted: May 31st, 2016, 16:01
Hello!
next attemp today...
Many thanks to Moltke!!!
After some attemps I got two different "PWD.bin" files
some with password "2708 " - seems to don't work
others with password "fuck " - seems to don't work
Tried to add file in Victoria which told me that filesize isn't correct...
So I opened with Editor and copy/past to Victoria
but still no luck
Error after DISPWD, Error: ABRT
After some more tries and hundreds of reboots i tried it without spaces after password...
Password "fuck" seems to work now
Victoria told me now:
Send password: "fuck". Type: MASTER
Starting security ERASE, ~100 min.
Now I have to be patient and wait till Security Erase is finished ;)
PostPosted: June 1st, 2016, 3:19
DRIVE SUCCESSFULLY UNLOCKED!
THANKS A LOT!
PostPosted: July 8th, 2016, 3:57
Bernie_AB, where did you get your Segate Tools, I need a link, every thing I find is infected?
PostPosted: July 8th, 2016, 5:31
victoria lock hdd wit password "fuck "
when you do security erase
this mean some one try to security erase hdd without unlock it
http://www.hpwlab.com
PostPosted: July 8th, 2016, 5:40
I think all of them look infected or at least some antivirus programs think they are.
Setup a Windows for infected programs, to be on the safe side. :)
Those who know don’t talk. Those who talk don’t know.
Users browsing this forum: we3fan and 54 guests
