Hey guys!
I've some problems with an ATA Locked ST500LT012 i've got from a friend...
Tried with ZOC and Seagate Tool (F3_hpwlab) but didn't success yet
I use a TTL CP2104 [url]http://www.ebay.de/itm/131749981549
[/url]
It's just connected with TX and RX as the Drive is 1,8V powered
(it's possible to get it connected)
With ZOC I always get error Messages (see Log)
With Seagate Tool I don't get password (don't know whicht track to scan for Password) and empty Track Reads
I've give it a new try today but still without success
Last time I just connected SATA Power, RX and TX from TTL Adapter to the Drive.
Now I also conneted GND from TTL adapter to the Drive...
Maybe this was the reason for SIM and RAW Error last time...
I also tried different buffer settings when i was asked this time - don't know what it is for...
Last time I just did what I've wrote...
I didn't use "m" command or anything else I shouldn't do yet
Just have these Programs from Internet I can work with (Freeware)
Script always stopps with error on line 176 and Bad Buffer Blocks...
[SERIAL/DIRECT] CONNECTED TO PORT COM4 (38400-8N1)
Boot 0x10M
SpinUpTime = 000006B0
TTR1 = 000007F9
(P) SATA Reset
RAW OFF
(DOS) Debug enabled
Intel 6G->3G
Send Status: Phy Ready without COMRESET, Status=50 PASS
TotalSuperBlks 00071C4D TotalValidSuperBlks 00071C4D
RETRY 0B48
176 +++ TMP=delstr(TMP,1,k-1)
239 +++ TMP2=TOASCII(i)
212 +++ call RECEIVE
50 +++ NXTADDR=GET_DATA(ADDR,DUMPLEN)
Error 40 running "C:\Dokumente und Einstellungen\Administrator\Desktop\CP210x_VCP_Windows\SUnlock.zrx", line 176: Incorrect call to routine
Error 40.13: DELSTR argument 3 must be zero or positive; found "-1"
Boot 0x10M
SpinUpTime = 000006BD
TTR1 = 00000806
(P) SATA Reset
RAW OFF
(DOS) Debug enabled
No Phy: Staggered spin bypass PASS
RETRY 0C41
I added also a detailed Log from ZOC for further research...
Is there any other special program I could get from anywhere which I could use to unlock???
Please help me to unlock this creepy piece of a Seagate Drive!
read also here for some further Informations and more photos:
http://www.hddoracle.com/viewtopic.php?f=2&t=1575&p=8824#p8824Best regards
Berny_AB
