Discussions related to PC-3000
Please no pirated software here!
Western Digital does not access user data
June 20th, 2024, 8:07
Hello everyone,
I tried to recover 2.5 western digital Drive, Model number WD20SPZX, When I try to access the files in DE, there is no user data available. I perform T2 recovery and backup modules and SA, The sectors look good on sector edit, also module 01A Error occurred. Could you please advise.
Thanks.
Re: Western Digital does not access user data
June 20th, 2024, 8:43
If sectors look ok, what is the problem for which you need advice?
June 20th, 2024, 8:44
The drive was blocked from access to SA by default?
Can you post a screenshot of the T2 reading?
How many percent does the tool say is filled with zeros after T2 reading?
June 20th, 2024, 9:06
hi @protech
if sector looks okay and you cant see file structure could be logical issue take full image and scan for lost Partition.
June 21st, 2024, 2:56
pepe wrote:If sectors look ok, what is the problem for which you need advice?
Hi pepe, appreciate the response. The problem is I'm getting an error entering DE and no access to client's data. I have attached the screen shots of the errors. Sectors are read using utility.
Read using utility. whole sectors are read fully
DE entered without drive ID
Trying to enter DE with Drive ID checked
June 21st, 2024, 2:59
Lukas wrote:The drive was blocked from access to SA by default?
The heads seem to write ok.
June 21st, 2024, 3:11
VSC_UNSUP_ACTION_CODE occurs when ovl is not loaded, so i suppose the drive restarted coz of some error and stayed without ovl. what does status sector say?
June 21st, 2024, 3:31
pepe wrote:VSC_UNSUP_ACTION_CODE occurs when ovl is not loaded, so i suppose the drive restarted coz of some error and stayed without ovl. what does status sector say?
Please forgive my ignorance but do you mean this?
June 24th, 2024, 11:03
Hi guys, any idea in this case?
June 24th, 2024, 13:50
Tools -> Utility extensions -> HDD State
Mikippp
June 26th, 2024, 2:13
Mikippp wrote:Hi,
Mikippp
Thank you Mikippp :mrgreen:
June 26th, 2024, 2:22
Here is the HDD state
HDD Info.docx
(22.78 KiB) Downloaded 285 times
State Sector.docx
(26 KiB) Downloaded 285 times
July 4th, 2024, 7:38
Any help on this drive is much appreciated.
