 Post subject: HGST HTS541010B7E610 doesnt access sector edit and DE
PostPosted: April 11th, 2025, 3:22
Hello everyone, I am working on a case involving an HGST HTS541010B7E610 drive, which is detected as part of the WD Palmer drive family. AT first sectors are readable; however, the drive slows down significantly when copying user files in the Data Extractor (DE). So I attempted to 'Solve Slow Responding Problems' procedure, locked UA writing, and applied T2 recovery. Shortly after, the sector editor stopped accessing the drive entirely, and even if i tried to get the sectors by utility mode and get access to the sectors I am unable to create tasks in the DE. Could someone please advise on how to proceed with this situation?
Here are the log Info:
SA SPT.................................. : 0
ROM Modules:
ROM version............................. : 02.1AP
Module 4F F/W version................... : 0002000J
Overlay F/W version..................... : 02.1BP
Servo F/W version....................... : 01.3C
Heads number............................ : 2
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
Relocations............................. : 0 (0)
Read ROM DCM............................ : Ok
Power up log reading.................... : Ok
Power up load dir data.................. : Yes
Power up load permovl................... : Yes
Power up load CFG data.................. : Yes
NN | Step | Time | Flags | Info | Description
62 | 20A | 4.83 s | 4000401214EFDFF | 5104370F | OVL_POWERUP_LOAD_RBBLIST(FM ERR HEADER II SIGNATURE INVALID)
66 | 227 | 4.83 s | 4000401216FFDFF | 51043746 | Load GPD-List (13A)(FM ERR NOT FOUND IN DIR)
85 | 223 | 5.60 s | 42884216DEFFDFF | 51043D9C | End Process 190(GPD-List (13A) not found)
DCM in module 47........................ : Z7
DCM in module 0A........................ : |R|3Z7AH39
To be able to create utilty based DE task, start "Prepare to get UA PBA access"
Family:................................. : Palmer 2.5"
Techno mode key......................... : Ok
HDD Status sector....................... : Ok
RAM:
System controller (SoC)................. : 88i1053A0 0x(5460)
HDD Info reading........................ : Ok
Cyl Count............................... : 512
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 1024 Kb
Flash ROM dir reading................... : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 726 802
SA regions address...................... : by default
SA regions address (RAM)................ : by default
Module 02 access........................ : Granted
SA SPT.................................. : 1944
SA Translator loading................... : Ok
SA defects assigned..................... : 2
ROM Modules:
Service area:
SA dir reading (ID)..................... : Ok
Dir items loaded........................ : 544
SA Access............................... : Copy 0,Copy 1
Configuration reading................... : Ok
CFG tech mode lock...................... : No
Self encryption drive................... : No
Master Password......................... : has not been set
User Password........................... : has not been set
UA writing.............................. : Blocked
DCM in module 02........................ : S|BRL|P3MZH7CARHV3KUUF
Drive identification reading ........... : Ok
 Post subject: Re: HGST HTS541010B7E610 doesnt access sector edit and DE
PostPosted: April 11th, 2025, 21:48
Write back your SA backup of 190 and undo slow fix. You probably just had a bad head. Heads map, run the good head first, then the bad head run with hardware retries. Maybe turn on TLER. In my experience Palmers usually have a slow reading head, head swap fixes them.
