Hello everyone, I am working on a case involving an HGST HTS541010B7E610 drive, which is detected as part of the WD Palmer drive family. AT first sectors are readable; however, the drive slows down significantly when copying user files in the Data Extractor (DE). So I attempted to 'Solve Slow Responding Problems' procedure, locked UA writing, and applied T2 recovery. Shortly after, the sector editor stopped accessing the drive entirely, and even if i tried to get the sectors by utility mode and get access to the sectors I am unable to create tasks in the DE. Could someone please advise on how to proceed with this situation?
Here are the log Info: SA SPT.................................. : 0
ROM Modules: ROM version............................. : 02.1AP Module 4F F/W version................... : 0002000J Overlay F/W version..................... : 02.1BP Servo F/W version....................... : 01.3C
Heads configuration..................... : by map Heads number............................ : 2 Heads number in use..................... : 2 Switched off heads...................... : No Heads map............................... : 0,1
Relocations............................. : 0 (0) Read ROM DCM............................ : Ok
Power up log reading.................... : Ok Power up load dir data.................. : Yes Power up load permovl................... : Yes Power up load CFG data.................. : Yes ----+------+--------+-----------------+----------+-------------------------------------------------------------- NN | Step | Time | Flags | Info | Description ----+------+--------+-----------------+----------+-------------------------------------------------------------- 62 | 20A | 4.83 s | 4000401214EFDFF | 5104370F | OVL_POWERUP_LOAD_RBBLIST(FM ERR HEADER II SIGNATURE INVALID) 66 | 227 | 4.83 s | 4000401216FFDFF | 51043746 | Load GPD-List (13A)(FM ERR NOT FOUND IN DIR) 85 | 223 | 5.60 s | 42884216DEFFDFF | 51043D9C | End Process 190(GPD-List (13A) not found) ----+------+--------+-----------------+----------+--------------------------------------------------------------
DCM in module 47........................ : Z7 DCM in module 0A........................ : |R|3Z7AH39
To be able to create utilty based DE task, start "Prepare to get UA PBA access"
Family:................................. : Palmer 2.5" Techno mode key......................... : Ok
HDD Status sector....................... : Ok
RAM: System controller (SoC)................. : 88i1053A0 0x(5460) HDD Info reading........................ : Ok Heads number............................ : 2 Cyl Count............................... : 512
ROM: Read ROM................................ : Ok ROM Data size........................... : 1024 Kb Flash ROM dir reading................... : Ok Flash ROM dir reading (Ext)............. : Ok (Active) Modules directory address............... : 726 802 SA regions address...................... : by default SA regions address (RAM)................ : by default Module 02 access........................ : Granted
SA SPT.................................. : 1944
SA Translator loading................... : Ok SA defects assigned..................... : 2
Service area: SA dir reading (ID)..................... : Ok Dir items loaded........................ : 544
SA Access............................... : Copy 0,Copy 1
Configuration reading................... : Ok CFG tech mode lock...................... : No Self encryption drive................... : No Master Password......................... : has not been set User Password........................... : has not been set UA writing.............................. : Blocked
DCM in module 47........................ : Z7 DCM in module 0A........................ : |R|3Z7AH39 DCM in module 02........................ : S|BRL|P3MZH7CARHV3KUUF
Drive identification reading ........... : Ok
| Attachments: |
