 Post subject: WD ROM Help
PostPosted: October 25th, 2026, 4:08
Could someone help me repair this ROM please ?
ROM.rar [639.48 KiB]
Downloaded 67 times
 Post subject: Re: WD ROM Help
PostPosted: October 25th, 2026, 4:50
Why do you think there is an issue with the ROM?
Mikippp
PostPosted: October 25th, 2026, 5:35
a donor ROM can also be used if you know certain information about the original ROM.
but again as Mikippp said why you think there is a problem with the ROM.. what is behavior of drive with original ROM ?
Data Recovery Pakistan
PostPosted: October 25th, 2026, 6:04
Mikippp
After unlock it and reflash it to the chip it give no sign of life
PostPosted: October 25th, 2026, 6:08
When i turn on the hdd it only gives the model number
PostPosted: October 25th, 2026, 8:22
now i have this issue
PostPosted: October 25th, 2026, 8:40
It appears that the drive is identifying itself with the information in the ROM:
Analysing active 0x0D module ...
Firmware Version = 05.01A05
World Wide Name = 50014EE213686C7E
Model Number = WDC WD10SPZX-24Z10
Serial Number =
That suggests that it cannot read, or make sense of, module 0x02.
Are you able to upload 0x02?
PostPosted: October 25th, 2026, 9:04
Serial Number =
this one ?
02_ByID.rar [1.6 KiB]
Downloaded 66 times
PostPosted: October 25th, 2026, 9:11
That looks OK. The model number is longer -- WD10SPZX-24Z10T1 (SA module 02) versus WD10SPZX-24Z10 (ROM module 0D).
PostPosted: October 25th, 2026, 9:36
yes
what should i do now ?
PostPosted: October 25th, 2026, 10:10
I have no idea. Yours peers would know better than me.
PostPosted: October 26th, 2026, 4:56
Core.iStores wrote:
Mikippp
was drive give full ID before unlocking the ROM? or this is the same behavior both with lock and unlock rom?
As per ROM WWN: 50014EE213686C7E07 you can cross check it with sticker if ROM is native.
from screen drive does have SA access, so problem could be with some SA module.. test the SA (all modules) to find out where is the problem ?
PostPosted: October 26th, 2026, 22:13
MindMergepk wrote:
Core.iStores wrote:
Mikippp
i checked the ROM and at the Serial Number is also empty
ROManalysis.txt [5.99 KiB]
Downloaded 49 times
PostPosted: October 27th, 2026, 0:59
rom looks native.
what do you call a sign of life?
does it spin up? did it spin up before unlocking?
If it spins, does it move heads? If not, problem is likely heads.
Since you get at least something in ID i would not call it 'no sign of life'.
PostPosted: October 27th, 2026, 4:52
pepe wrote:
rom looks native.
After doing some attempts the ROM worked but it gives this results that shows in the attached photo
I managed to read some modules by ID and reading by Track or ABA it couldn’t read at all, it’s gives error
PostPosted: October 27th, 2026, 13:05
The loader is not loaded into memory
Load the loader and check the SA modules
A disk with this firmware version can be found in the files section.
https://files.hddguru.com/index.php?act ... ty/Palmer&
Mikippp
Users browsing this forum: No registered users and 14 guests
