 Post subject: Data recovery possible?
PostPosted: April 17th, 2010, 18:06
My macbook's can't be restarted after HDD failed. Mac replaced the hdd and give me back the original HDD. It's a Fujitsu made 160Gb model MHY2160BHD.
It can't be found normally using a SATA to USB PCB (no suprise). using third party software, I can see the drive. But Testdisk can't find the partition files and Data Recue II scanned 3Gb (it took 2 days) says no file can be found?
Any solution? Thank you.
 Post subject: Re: Data recovery possible?
PostPosted: April 17th, 2010, 19:31
You can try ufs explorer.
Zero Alpha: zeroalpha.com.au
PostPosted: April 17th, 2010, 19:59
You should make an image of a failing drive (if you can) and recover from it, NOT the original patient. Working a defective drive by trying to get files from it can cause its destruction, preventing future data recovery.
http://www.datasaversllc.com
PostPosted: April 18th, 2010, 1:29
I wouldnt be surprised if there was some level or surface damage here. If initial recovery attempt is unsuccessful, or an image cannot be taken, it would be wise to consult a professional, or trash the disk.
PostPosted: July 2nd, 2014, 7:21
Hard drive failures can be anything from components attached within to software malfunctions & corruptions. So if your Mac shuts down without you requesting that do so, begins reporting a whole host of disk errors then shut the computer down and contact Apple Hard Drive Recovery agents. They will diagnose the nature of the problem from the information you give them & can help you move forward with the recovery of your data.
PostPosted: July 2nd, 2014, 7:28
Firstly advancedata welcome to the forum.
Secondly were you aware that the post you replied to is over 4 years old?
Loki
Users browsing this forum: Google [Bot] and 70 guests
