Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: DIY ROM SWOP Gone WRONG
PostPosted: April 6th, 2010, 22:31
thanks Rameez will locate one...
PostPosted: April 10th, 2010, 10:33
Hi guys and gals
As promised im giving you an update on my PCB and ROM swop
and im happy to say i successfully completed my first DR experiment...
things learnt...
1. You must be VERRRRRRRY patient with the ROM desolder and Resoldering process, Clean up during and after your work...
2. rameez... you do not need the last 3 digits for the WD Drives i was working on.. As long as the first 10 digits match you are good to go... well thats what i read online neways....
eg My orginal PCB was 2061-701335-E00 AC / 2060-701335-005 REV A
my Donor PCB was 2061-701335-E00 AF / 2060-701335-003 REV B
Steps in this process was:
1. Locate and unsolder ROM chips from both DONOR and FAULTY PCB's
2. Solder ROM to DONOR PCB
3. Clone drive using Media Tools Pro
4. Write image to known working 500GB drive
5. Connected drive to working PC and checked data
if there is anything else i should have done here please let me know as im a NEWBIE.. to DR
PostPosted: April 10th, 2010, 20:37
Congratulations!
PostPosted: April 10th, 2010, 21:46
lucky it worked for you , i have never been so lucky .
PostPosted: April 10th, 2010, 21:59
rameez wrote:
In these drives the last 3 digits do matter so you need to find the exact pcb .
do you know what's the difference during 003 and 005? 8)
data recovery service[/b]
PostPosted: April 11th, 2010, 2:53
Good Job!!!!!
Not many people are so lucky as you are in DIY Recovery...
PostPosted: April 11th, 2010, 6:22
networkpc3000 -- no i dont know what the difference is but if you do please share with me as i read a post online which said i didnot need to match the ENTIRE number... like i said im still a "baby in arms" when it comes to DR
PostPosted: April 11th, 2010, 6:40
Networkpc3000
this is the info i which made me believe i could use the 003 REV B PCB
http://www.hdd-parts.com/20091010.html
PostPosted: April 11th, 2010, 19:30
You're very lucky doing it this way ,and not frying the chip.
Normally you should have used SMD temperature controlled soldering/desoldering device together with the paste. :
http://www.youtube.com/watch?v=k7j6U_dwM3M
http://www.youtube.com/watch?v=o9PgwMzrk2g
Here are some very nice guides on SMD soldering :
http://www.infidigm.net/articles/solder/
http://www.avrfreaks.net/modules/Freaks ... 0Guide.pdf (see for the trick with wire)
Hot air guide with 175$ station : http://www.sparkfun.com/commerce/tutori ... ials_id=36
If you have money to spent,you might consider one of these (Weller) : http://www.youtube.com/watch?v=kjKPzYvcD5I (that's were I learned it on)
Take any old print board,and exercise first on it.
Then perform the real deal.
The trick that you should apply to pull this off ,is to be as possible so that the internal circuitry in the chip isn't heated up for a long time.
The longer you heat it up at soldering temperature,the more chance on damage.
Needless to say that grounding during soldering is IMPERATIVE.
Kind regards,
K.
PostPosted: April 11th, 2010, 21:21
@networkpc3000,
Its in the CPU ,
PostPosted: April 13th, 2010, 23:15
ktheking
Thanks for the info... i like that hot air tool ALLLLLLOOOOOOOOOOOOOOOOT :)
PostPosted: April 17th, 2010, 23:28
rameez wrote:
@networkpc3000,
Its in the CPU ,
i can use 003 instead of 005.
PostPosted: April 18th, 2010, 21:22
@networkpc3000,
It depends , the drives i have here are all MDT some of the have 003 and some have 005 both working perfectly in there places if in interchange i get knocking .
PostPosted: April 18th, 2010, 23:08
darkosski wrote:
Hi guys and gals
things learnt...
Well ,
You Should Practise With Soldering And Desoldering Skills a Lot you Need To Learn a Lot ,this Is Not a Good Job At Soldering
PostPosted: April 21st, 2010, 2:54
@Amarbir
Thanks for the input... :)
PostPosted: April 21st, 2010, 7:10
Flux Pen + Solder Wick and a Flux cleaner would have made your life easier. Of course some solder to finish the job :O)
Looks like you used a blow torch and hammer 8oP
PostPosted: April 21st, 2010, 22:20
@guru hehhehe you live and you learn... that was my first.. well second attempt...and you are correct i dint have the correct tools...... the 3rd will be much cleaner just ordered a SMD Hot Air Rework Station 952 Welding Soldering Iron a flux pen and solder paste :D so next job will be clean as a whistle :)
PostPosted: April 23rd, 2010, 4:10
Im pretty certain a pro recovery would have been more suited considering the time and money your spending !
PostPosted: May 7th, 2010, 19:35
Good on you mate. Im scared to look at the price of one of those things..
But you cant go wrong with Weller, my dad used a weller soldering iron and trasnformer(anolog) and now im using it today.. its like 20+ years old and still works perfect - few tip changes obviously :P
Good luck with your next project :)
Free Solutions
PostPosted: May 8th, 2010, 3:03
Weller soldering iron or whatever brand is insufficient for desoldering. Hot air / infrared and tools and chemicals and a lot of practice are needed NOWADAYS.
For soldering, depending on how good you are, you can use everything you want.
Users browsing this forum: Google [Bot] and 99 guests
