Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: Western Digital Head issue
PostPosted: April 26th, 2010, 11:42
What is the deal with these Western Digitals with 1 head failing? I have seen a lot of this issue too often. Can anybody shed the light on the cause of this failure? A lot of them seems not to respond to head exchange. I would like to know what you guys think about this.
The last word from the dying patient, data.
www.datamediarecovery.com
 Post subject: Re: Western Digital Head issue
PostPosted: April 26th, 2010, 11:51
alignment.
PostPosted: April 26th, 2010, 11:56
More customers :wink:
PostPosted: April 26th, 2010, 11:58
yeah, that is right. But some of us are scratching our heads on this problem.
PostPosted: April 26th, 2010, 12:07
Russwinters wrote:
alignment.
interesting answer. A lot of them, head 0 is the issue. Could there be a platter shift on these drives? I know the alignment issue is a guarded top secret.
PostPosted: April 26th, 2010, 12:08
Which Western Digitals?
PostPosted: April 26th, 2010, 12:13
a lot of them--WD2500AAJS-40VWA1, WD3200AAJS-55RYA0--
It seems like a lot of Tornado (2d) families have this issue. Most of the families suffer this type of issue from time to time.
PostPosted: April 26th, 2010, 12:19
One funny thing about these drives, they do not respond to no other heads but their own. I find this very baffling.
PostPosted: April 26th, 2010, 12:22
I think you are doing something incorrectly. Head exchange is not easy on WD, especially 3,5" models, but is not impossible and do generally respond with donor HSA.
They do suffer with several issues such as the alignment issue, but there are methods to work with this issue.
PostPosted: April 26th, 2010, 12:56
Yeah, I think the general consensus here is that the alignment has to be taken into consideration. One thing that I can't understand is that head exchange with its own head work as previously. Nothing different was done, except a different head.
Even with a matching firmware drive, it does not response.
PostPosted: April 26th, 2010, 15:08
Gus,
How are you attempting to combat the alignment issues inherent in WD drives since they have screws which control alignment going through the external shell itself? How sure are you that alignment isn't your main problem the whole time and that the HSA is not the issue?
PostPosted: April 26th, 2010, 15:19
MadMex,
That is the million dollar question. In this one area, many of us are left behind :-) How do you test for that issue?
PostPosted: April 26th, 2010, 15:29
tbh I doubt any of the people who are "in the know" are going to leak much on this
PostPosted: April 26th, 2010, 15:38
I know this much. I have been in this forum for a long time; and I know what can be shared and not.
a little clue can be helpful. If somebody is willing to sell the info, I am all ears. :-)
PostPosted: April 26th, 2010, 16:36
I can handle these and other big WD drives in UK :-)
It took quite a lot work to get it right that's all I'll say!
PostPosted: April 26th, 2010, 17:01
yeah, these are tough questions... :)
PostPosted: April 26th, 2010, 17:03
Well, the questions are easy.
The answers are the tough bit!! :lol:
PostPosted: April 26th, 2010, 17:27
If you were in the US, I would have outsource them to you.
PostPosted: April 26th, 2010, 17:33
I will smile along.
PostPosted: April 26th, 2010, 18:45
It's been a bit of a learning curve, but to me, the Royal series of drives (including Tornado) are probably the easiest to do head swaps on. Our batting average is high. It didn't start out that way. It is not so much a matter of esoteric knowledge and high tech procedures as much as good methods and habits.
We struggle with Zeus (KS, etc.) series because of alignment, as well as the pre-Royal versions. I am finishing up a WD1600BB that another, bigger data recovery company declared was unrecoverable. We should get about 99%. But it has taken weeks of imaging, swapping heads, etc. to finally get the balance. The media seems to be degrading and fouling the heads.
Patience and persistence are key.
Jono
http://www.datasaversllc.com
