 Post subject: How to deal the 1.5TB with firmwire CC1H 7200.11?
PostPosted: April 15th, 2010, 7:09
Barracuda 7200.11
Modle:ST31500341AS
Firmware: CC1H
Now the harddisk cannot be recoginized in the Bios.
After power on,it give out low noise something like unable to spin up.
So,I want to connect it to RS232 terminal in the way :
http://www.msfn.org/board/solution-seag ... l__7200.11
But the terminal has no response no matter I press "Ctrl+T" nor any other Keys.
(It shows "F3 T>" when the HDD is replaced by 500GB or 1TB 7200.12)
 Post subject: Re: How to deal the 1.5TB with firmwire CC1H 7200.11?
PostPosted: April 16th, 2010, 21:36
check baud rate .
PostPosted: April 16th, 2010, 23:32
Use 38400 8 None 1 None
I am in the same boat with you except i can still see my drive but it has SMART errors, I am trying to recover my data too...
PostPosted: April 17th, 2010, 5:16
Terminal is not going to fix your seized motor.
PostPosted: April 17th, 2010, 5:57
At least not yet.
PostPosted: April 17th, 2010, 9:39
You should be able to confirm if the motor is seized as the terminal will output.
"Buzz Buzz Buzz"
Over and over as the motor tries to start.
Leigh
DataWreck Data Recovery Services
www.DataWreck.co.uk
PostPosted: April 17th, 2010, 10:21
"Buzz Buzz Buzz"
Leigh
Not on this disk. This is F3 series.
PostPosted: April 17th, 2010, 10:34
Fair point, your right. Have been at older ones all afteroon :)
www.DataWreck.co.uk
PostPosted: May 2nd, 2010, 2:32
rameez, hi rameez
salm val e kum
i am sachin vora we had talk before years n i would like to talk again if can i want some suggestions
Users browsing this forum: No registered users and 253 guests
