Post new topic Reply to topic  [ 26 posts ]  Go to page Previous  1, 2
 Post subject: Re: WD5002ABYS detectable but not working
PostPosted: May 6th, 2010, 7:27
Have you ever worked with it ?
I doubt.
PostPosted: May 6th, 2010, 8:40
BlackST wrote:
joe1203 wrote:
god is dead :D :D
... your drive too and your wallet will not be so good , I think. :D
Just curious : what do you plan to do with SD box ? Have you ever worked with it ?
I have ZERO experience with SD Box, but here is my rough plan
1) Download firmware from donor drive
2) Backup the MCU adaptive data from malfunctioned drive (abb. as MHD)
3) Connect MHD to the box
4) Do SA defect scan
5) If fail, probably broken heads -> send to pros to fix it. (Since I need to recover all data, disabling the broken heads are not a good idea)
6) If head is ok, do SA defect scan
7) If ok, power off the drive and see if it works
7) If no, do FW upload
8) If still not work, send to pros
PostPosted: May 6th, 2010, 8:42
In theory this is good, but without understanding of module dependencies, and adaptive modules, and wide variety of SA to ensure compatibility it will be a very difficult.
PostPosted: May 6th, 2010, 8:46
In theory this is good, practically ... Good luck. Nothing else to say.
PostPosted: May 6th, 2010, 12:10
Thank you for your comment.
I really have no understanding of each module.
I only know those easy one such as G-List/P-List/SMART etc.
However, the whole SA has too many modules and is too complicated. :(
PostPosted: May 6th, 2010, 12:12
What else should I pay attention practically? :?:
Users browsing this forum: No registered users and 203 guests
