 Post subject: Where is the diode?
PostPosted: June 8th, 2010, 13:26
Fried the drive......again.
Last time I just popped off the TVS diode and life was good for data recovery.
Anyone know where it is on this one?
 Post subject: Re: Where is the diode?
PostPosted: June 8th, 2010, 13:28
The two right under you power connector. Test them
Iorana Haraharaini
PostPosted: June 8th, 2010, 15:46
Can you please clarify "test them".
I have a Fluke Digital Multimeter (auto range); should I just set it to resistance mode and check for a dead short? Or use the continuity checker that beeps of shorted?
The REAL Joe
PostPosted: June 8th, 2010, 17:14
http://lmgtfy.com/?q=how+do+i+test+diodes
PostPosted: June 8th, 2010, 18:11
Thanks for the cryptic answer. You couldn't just post a couple of simple instructions specific to testing the diodes on-board on a Harddrive here?
/TRJB
PostPosted: June 8th, 2010, 18:39
Before you guys go "randomly" probing about for "diodes" be aware that some cheap multi testers use a 9v battery.
so if you have your multi-tester set to "sounder", there is a possibility you can damage some of the Cmos inputs for some chips if you reverse bias the substrate of the device.
In English :
You can seriously shorten the life of some chips , by using the wrong analysis protocols
and please ALWAYS remember you anti-static wrist strap with integral resistor and grounding wire.
(notice that all these "pro" disk repair kits do not come with a cheap reusable $3.00 antistatic wrist band)
Remember safe repair is like safe sex: always wear the correct protection. :wink:
Universal Declaration of Human Rights: Article 19
PostPosted: June 8th, 2010, 18:41
No, you wouldn't learn anything by me telling you how to test a simple diode.
PostPosted: June 9th, 2010, 9:32
What is the open circuit voltage and short circuit current of a cheap multimeter?
PostPosted: June 9th, 2010, 9:48
/TRJB
viewtopic.php?f=1&t=14361#p105568
PostPosted: June 9th, 2010, 10:10
You don't check a diode with Ohm Meter, check it with a Diode tester option.
https://www.mjm.co.uk/
Users browsing this forum: No registered users and 86 guests
