 Post subject: reasons not accepting terminal commands
PostPosted: July 12th, 2010, 7:35
can some guru explain probabable reasons for an 7200.11 drive with SD15 firmware does not accept terminal commands if connected only pcb?
It gives typical LED error if connected to HDA.
 Post subject: Re: reasons not accepting terminal commands
PostPosted: July 12th, 2010, 8:09
user error?
Zero Alpha: zeroalpha.com.au
PostPosted: July 12th, 2010, 9:32
yes it gives firmware error LED: 000000CC FAddr: 0024A051 ,but when pcb removed , even after pressing Ctrl+Z ,it does not come to T>
PostPosted: July 12th, 2010, 9:47
Yes, sometimes they do that.
PostPosted: July 12th, 2010, 10:59
My question is " why" they do so?
PostPosted: July 12th, 2010, 11:20
Because they are programmed that way?
PostPosted: July 12th, 2010, 11:23
Well the days of free Lunch are over :mrgreen:
Why not take a bunch of drives and do some research, this is always the best way to find your answer. Once you find your solution you can come back and share what you found.
PostPosted: July 12th, 2010, 11:29
Selfish ! :mrgreen:
PostPosted: July 12th, 2010, 11:38
BlackST wrote:
Selfish ! :mrgreen:
ohh... :shock: Mr. BlackSt, why is that?
PostPosted: July 12th, 2010, 15:19
I think BlackST is being sarcastic! :roll:
PostPosted: July 12th, 2010, 15:32
oh, ok got it :D
PostPosted: July 13th, 2010, 11:07
One reason for sure is those drives which do not come to terminal have a common reason ,
another PCB is tried on these drives which must have caused firmware change on HDA.
PostPosted: July 13th, 2010, 11:09
If free luch is over I do not need your USELESS free advice as well . This request was only for guru's and not ordinary DR technicians who are ego driven.
PostPosted: July 13th, 2010, 11:23
1) First of this has nothing to do with Ego
2) You really don't need a guru to figure this out
3) You should not feel offended, my advice was not all that bad :D
PostPosted: July 13th, 2010, 11:39
Mankind is sex driven, DR is money driven, social relationships are ego driven...
PostPosted: July 13th, 2010, 11:47
Well said BalckST.
But what drives HDD? :wink:
HWHacker
Smiles
PostPosted: July 13th, 2010, 11:51
Magic and secrets
PostPosted: July 13th, 2010, 14:35
and hdd spray !!
PostPosted: July 14th, 2010, 19:40
My opinion of the "gurus" diminishes on a daily basis.
If you've come here thinking that this is a traditional forum, then you're sadly mistaken. HDD Guru is more of a marketplace or referral centre than a helpdesk.
Good luck, anyway.
PostPosted: July 14th, 2010, 21:18
If you've come here thinking that this is a traditional forum, then you're sadly mistaken. HDD Guru is more of a marketplace or referral centre than a helpdesk..
I think I would say HDD Guru is more of a center for networking, discussion, and collaboration between like-minded engineers/technicians. Helpdesk, certainly not. The subtitle for the main forum is "Data Recovery and Hard Disk Repair discussions", not "Post here for someone to tell you how to fix your hard drive" or "I just bought a PC-3000 but don't know anything about hard drives so someone tell me what to do"
Users browsing this forum: No registered users and 194 guests
