 Post subject: Seagate Tonka15 7200.9 300 GB problems
PostPosted: July 14th, 2010, 9:09
Hello hddguru´s
Hdd has 6 months is formated hdd filled zero, it is no longer recognized by bios
any help please :)
Connect to rs232
ST33000822AS 7200.9
3.AAE 12-09-05 11:29 AAE,35_S_5_S1,3A
4096k x 16 SDRAM
TONKA15 - 1_Disk S.59 12-09-05 11:26
Head Mask FFFF - Switch to full int.
Spin Ready
(P)SATA Reset
Failed sys sect. write
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Unable To Load Overlay 01|000A
Code - 1B Track FFFFF(15CC8).0.012 Sns FFF Rty F7FF.40.80FF Rtf 1800 LBA 00000766
> reset
VALID Cert Disk Code Detected - Revision # .08H
Help me please
 Post subject: Re: Seagate Tonka15 7200.9 300 GB problems
PostPosted: July 14th, 2010, 11:01
'unable to load overlay' , firmware damaged. Need professional help to restore functionality or buy another one. Such repair - if possible - is cheap but not everybody does it.
PostPosted: July 14th, 2010, 12:45
Or heads weak/failing. Common issue.
PostPosted: July 15th, 2010, 14:52
Nope, almost certainly not firmware damage.
Can get confused that it is firmware damage because some ace has solution for
"Unable to load Overlay", but this possible solution, (which does not work very often),
is just a bypass of some Seagate function in program to give access to drive.
But this solution does not fix any firmware permanently, just temporary bypass.
So there is no firmware damage
Solution in almost all cases requires some physical work.
PostPosted: July 15th, 2010, 15:04
change heads and if there is no media damage you should be good to go :D
PostPosted: July 15th, 2010, 16:15
just checked ; coffeebean you're right, but would need to see if applies to this case...
Users browsing this forum: Google [Bot] and 360 guests
