Post new topic Reply to topic  [ 72 posts ]  Go to page Previous  1, 2, 3, 4
 Post subject: Re: General (and not general)Seagate questions - for everyone :)
PostPosted: June 12th, 2009, 12:05
ccc wrote:
Also try to look at this post:
7200-stuff-mess-t12153.html#p79225
It may help you....Or try to rewrite the 4 sector of vendor track...
Rgds
Unfortunately not works, this is a 7 series drive....
I have the Salvation Seagate Doctor only, wich is a s**t. :D
I have no backup from the vendor track, only the modules, wich is in the tool.
So, maybe the 4 sector is inside somewhere in the modules, but this takes too much time to invetigate how can i select this and where to write up. :|
PostPosted: June 12th, 2009, 13:08
Check your PM. :mrgreen:
PostPosted: June 12th, 2009, 13:20
Got it, thanks. :mrgreen:
PostPosted: June 18th, 2009, 22:57
try F,,1 instead of F
that will set stuff values no matter what .
PostPosted: June 19th, 2009, 0:38
Another answer is that salvation tool backs up 4th sector of vendor track as a "module", they just call it something silly and don't mention it anywhere.
PostPosted: June 18th, 2010, 11:40
Gurus,
I am searching for loader or modules or any resources for snowmass (barracuda IV) 80GB AMK 3.10.
If you have any for this, please let me know
Thanks.
Janos
PostPosted: June 19th, 2010, 9:37
problem solved without resources. :)
Thank you for who taking time to check it for me....
PostPosted: August 17th, 2010, 13:38
Hi
I have the same problem:
Interface task reset
4096k x 16 SDRAM
TONKA15 - 1_Disk S.68 03-14-06 11:17
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
(P)SATA Reset
Stuff Was Unreadable3.AAH 03-14-06 11:19 AAH,35_S_5_S1,4T
T>
Does anyone have a FW for this model?
What should I put on the ASCIFE command, to do a "manual" reset? Where do I get that info?
ACELab partner
PostPosted: August 18th, 2010, 4:47
What are you using for repairs? Also what is complete model, you will need to match capacity also if you plan to replace STUFF info.
PostPosted: August 18th, 2010, 7:34
Hi HDDGUY
I'm using SD Doctor.
The disk is a Barracuda 7200.9
P/N: 9BD133-304
FW: 3.AAH
Data Code: 06365
Thank You
ACELab partner
PostPosted: August 18th, 2010, 11:39
ASCIFE dont work on this model , rewrite vendor track of any hdd of same model .
PostPosted: August 18th, 2010, 13:59
I think it's solved.
Uploaded the module INFO, and I already could do a Surface Scan.
I just need to connect it to a PC (they are all busy now...) to check if it's OK.
ACELab partner
Users browsing this forum: Google [Bot] and 257 guests
