 Post subject: Western digital 2tb mybook HDD
PostPosted: August 25th, 2010, 7:30
hi guys, need your help ! my WD 2TB mybook HDD is security protected by a single password (to access the drive in my comp, view its contents, and continue to add more data). the password box comes up every time you plug into your comp.
since this afternoon ive been locked out, i knew my password but entered it incorrectly four times and only just found out i had the numlock turned on, on my laptop. GREAT!!!!. now the WDsmartware software wont let me access my files
any ideas of how to get access again please much appreciated......
 Post subject: Re: Western digital 2tb mybook HDD
PostPosted: August 25th, 2010, 7:32
Can you tell the model of the box?
PostPosted: August 25th, 2010, 7:39
hi dmarques the model number is WDBAAF0020HBK
PostPosted: August 25th, 2010, 9:37
Well, I'm still not 100% what kind of encryption does it use, but I'm sure you'll need help from a pro to do it.
Other option is try to contact WD in order to check if they have any solution for it.
PostPosted: August 25th, 2010, 11:21
My understanding is the WD SmartWare loads from a small partition on the drive (via autorun)
and allows the user to input the password that is used to access (encryt/unencrypt) the data on the rest of the drive.
I would have thought the software would merely lock out for a period of time if the incorrcet password is entered too many times
Henec it might accept it later today or tomorrow
There have some been some other threads on here about Smartware and the Initio chip that does the encryption
PostPosted: August 25th, 2010, 11:25
Also a discussion at
http://community.wdc.com/t5/WD-Smartwar ... /td-p/5304
etc
PostPosted: August 26th, 2010, 9:43
hey guys good news xsoliman was right it only the HDD only locks you out for a period of time! i left it unlpuged and power off for 24hrs (could have been less time than that, but 24 seemd long enough). pluged it bak in, password option came up and got accepted back into my drive.. STOCKED
thanks to everyone who offered there support :)
PostPosted: August 26th, 2010, 9:52
Nice... some of us learned something...
Users browsing this forum: Google [Bot] and 329 guests
