 Post subject: Please help with Hitachi DK23EB-40
PostPosted: August 24th, 2007, 2:15
Hitachi DK23EB-40
40 GB , 5400 rpm....
from Dell laptop
Dead Pcb , no visible that any burnt , fuse s ok....
I can not find donor hdd ....
Is there posibility that pcb could be repair...
Did anybody work with it ?
please for any help !!!
Spasavanje podataka
 Post subject: Re: Please help with Hitachi DK23EB-40
PostPosted: August 24th, 2007, 7:07
If you replace pcb by another pcb, even if it's not totally compatible, what do you get?
PostPosted: August 24th, 2007, 8:20
I have find hard 20 gbfrom the same family:
Hitachi DK23EB-20
20 GB , 5400 rpm....
and put that pcb on my hdd
and my hdd is recognized
everywhere ( bios and win)
like Hitachi DK23EB-20 and in windows is visible only 20 gb capacity (~ 39 000 000 LBA),
instead 40 gb and ~ 78 000 000 LBA .
shortly my disk is recognised with half capacity and could not get data from him.
Also it is interesting in that series of hdd :
serial number of hdd is written somewhere on pcb
that my hdd ( 40gb ) with that other pcb exept lower capacity
give and ser. no of donor ( 20gb )hdd.
well , i am shure that my disk is mehanically fully ok
but it need the PCB from the same capacity hdd ( 40 GB)....
Spasavanje podataka
PostPosted: August 26th, 2007, 6:53
Any idea ???
what do it ?
Spasavanje podataka
PostPosted: August 26th, 2007, 10:20
You should transplant ARM chip from your bad board to the donor.
PostPosted: August 27th, 2007, 2:23
what is that circuit ?
Spasavanje podataka
PostPosted: August 27th, 2007, 8:22
It's a CPU with masked ROM.
PostPosted: October 1st, 2010, 6:59
hi
i have DK23EB-40 which doesn't show up.
we have an identical drive.
i understood from this forum to transfer/echange Marvel chip or some other chips.
can anybody send me the location and which chips to transfer?
Ii am attaching a picture of the mbo.
thanks in advance
ephraim
PostPosted: October 1st, 2010, 18:58
Does the drive spin up?
BTW, the "adaptive" data appear to be in the Marvell MCU (big "M").
PostPosted: October 2nd, 2010, 23:48
hello fzabkar
thanks for your answer.
it's a big chip this marvell. can it be replaced. do u know how?
do u know about the other chips on this board.
yes the drive spins up.
tks a lot
ephraim
PostPosted: October 3rd, 2010, 18:54
If the drive spins up with the original PCB, then the problem is most likely not with the board. Otherwise, if it doesn't spin up with the original PCB, but spins up with the replacement, then the chip swap should work. However, you will have a hard time finding a shop that has the necessary smt rework equipment to do this job for you.
The following URLs should help you identify some of the other chips:
easy-faultdiagnostic-troubleshooting-must-try-t12319.html
http://www.users.on.net/~fzabkar/HDD/HDD_ICs.txt
http://www.users.on.net/~fzabkar/HDD/TVS_diodes.txt
PostPosted: October 4th, 2010, 2:46
hello fzabkar
thanks for your answer again.
your info was very good, but:
the layout u sent is for wdxxx drive.
do u have a layout of hitachi's dk23eb-40?. i was strating to look in the last two links and didn't find.
there might be aome similarities but i don't like to take risks.
-u didn't answer this question--> it's a big chip this marvell. can it be replaced. do u know how?
tks a lot again
ephraim
PostPosted: October 4th, 2010, 3:32
You need something like this:
http://www.google.com/images?q=%22smt+r ... 22+station
I don't have any schematics for your drive. If I were troubleshooting it, I would trace the DC-DC converter circuits, and use some basic electronic troubleshooting principles. That's why I directed you to the WD and Seagate URLs.
BTW, I'm not a data recovery professional. I'm only following Starling's advice.
That said, I'm wondering whether the smaller of the two square chips is an EPROM or flash memory. Can you tell us the part numbers on the 4 biggest chips? Your photo doesn't help at all. :-(
PostPosted: October 4th, 2010, 3:43
To avoid a lot of frustration :
1) "clairvoyance" doesn't help - proper diagnose with the right tools does.
2) most likely the problem is FW/heads on this series. See 1)
3) to confirm point 2) : check if drive spin up and does at least partial calibration , but the drive should not click. If clicking, 99% is internal problem.
4) at this point, if you don't have a HW or proprietary diagnostic tool to access FW and proceed with further analysis, is GAME OVER.
5) As the drive is old and this series had some "peculiarities", take into account the possibility of media damage too (5-10% in my opinion).
The possibility of MALFUNCTION of the PCB is low but also can be. It can be pinpointed in short time with the right tools.
PostPosted: October 4th, 2010, 9:04
fzabkar and BlackST thank you very much both of you.
BlackST, what is clairvoyance?
can u both recommend for the best tools for this case?
thanks a lot again.
brgds
ephraim
PostPosted: October 4th, 2010, 17:14
You haven't answered my questions.
Does the drive spin up with the original board?
What are the numbers on the 4 big chips?
Users browsing this forum: No registered users and 70 guests
