 Post subject: Hitachi HTS541616J9AT00
PostPosted: October 7th, 2010, 5:34
Hello !
I have a Hitachi 160gb that been sitting in my Archos 504, unfortunately it broke down, so i took the hdd and put it in a box, i then connected it to my windows7 desktop to use! now W7 say "windows was unable to complete the format"
is there any way i can still format it so i can use it again??
Thank yous
 Post subject: Re: Hitachi HTS541616J9AT00
PostPosted: October 7th, 2010, 5:50
First run this porgram on it
http://hddguru.com/software/2006.01.22-HDDScan/
Set it to Verify- And check for bad sectors?
Free Solutions
PostPosted: October 7th, 2010, 6:19
Thank you !!
I got the prg and did the Verify!! it say its finished!! but nothing ells sems to happend!!
mind there is nothing on it that i need to recover or keep!!!
Whats next?
PostPosted: October 7th, 2010, 6:26
Ok? Did you look at the map- were there any RED blocks?
All i can recommend now is to use the Erase tool
http://hddguru.com/software/2006.04.13-HDD-Wipe-Tool/
Erase your hard drive then Scan it Again with Verify. And make sure to check the MAP for any coloured blocks especially for red.
:D
Free Solutions
PostPosted: October 7th, 2010, 7:01
Hi again!!
its wiping it now!! seems to be incredibly slow!! (started at 11:30 and only 5 blue bars on the counter!!)
What is the MAP you are mentioning?
don't know if this says anything useful!!
Current date and time: 07/10/2010 11:30:17
Hard Disk Wipe Tool 2.35 build 1178; http://hddguru.com
Device details for Xitishi HTC549696J9IT80( [160.3 Gbytes]
Details are unavailable because the device is not a Native IDE or SATA device.
i will give it time !!!!
PostPosted: October 7th, 2010, 8:03
Patience but it should not be more than 1 hour really?!
Free Solutions
PostPosted: October 7th, 2010, 12:11
Is the program really reporting a "Xitishi HTC549696J9IT80" or is this a typo ?
If it is real, then there is something wrong. Perhaps bad contact or bad cable.
If after checking cable you still got this, then its the drive itself that is bad.
Dobre
Murphy was an optimist
PostPosted: October 8th, 2010, 5:30
You can compare the good and bad data using Debug in a Windows DOS box.
debug
-f 100 140 0
-e 100 "Xitishi HTC549696J9IT80"
-e 120 "Hitachi HTS541616J9AT00"
-d 100 13f
12EB:0100 58 69 74 69 73 68 69 20-48 54 43 35 34 39 36 39 Xitishi HTC54969
12EB:0110 36 4A 39 49 54 38 30 00-00 00 00 00 00 00 00 00 6J9IT80.........
12EB:0120 48 69 74 61 63 68 69 20-48 54 53 35 34 31 36 31 Hitachi HTS54161
12EB:0130 36 4A 39 41 54 30 30 00-00 00 00 00 00 00 00 00 6J9AT00.........
-q
It appears that the errors occur in bits 12 and 3, or bits 4 and 11, depending on the endianness. So it does look like a cabling or interface issue.
In fact the suspect bits are adjacent to each other in the cable (Data 3, 4, 11, 12):
http://pinouts.ru/HD/IdeInternal_pinout.shtml
PostPosted: October 8th, 2010, 12:21
My 2.5 to 3.5 inch adapter is like that. Have to get it aligned perfectly or it does the exact same thing, same bits. Better to use a laptop to test it... although, it is better to use the adapter first to see if an unknown drive spins up correctly in an old desktop computer first, as cheap insurance.
I say this because I once had a Toshiba laptop drive fry my IDE controller on a laptop. Luckily it was an only an ancient Compaq Presario K62-300 missing parts that I used only as a testbed.
http://www.shopgoodwill.com/listings/li ... ?catID=176
Good source for cheap testbeds, just be sure it isn't a difficult "This laptop is protected by a password" disabling session. Some laptop passwords are almost impossible to remove.
http://www.youtube.com/user/TerraformingMaster
Users browsing this forum: No registered users and 261 guests
