 Post subject: SMART status ON, can be cleared ?
PostPosted: October 7th, 2010, 4:27
I discovered this forum, which is great! :D
Actually I have two SAS drives, which have the smart status ON, caused by a faulty raid controller.
My question is : is it possible to clear this smart status? What is the right tools for this ?
Thanks!
 Post subject: Re: SMART status ON, can be cleared ?
PostPosted: October 7th, 2010, 4:29
Possible and there are NO tools in the public domain.
PostPosted: October 7th, 2010, 6:28
Only DR services can do that?
PostPosted: October 7th, 2010, 7:29
DR Services probably have no idea also
PostPosted: October 7th, 2010, 7:31
:mrgreen:
PostPosted: October 7th, 2010, 8:10
Not ALL :mrgreen:
PostPosted: October 7th, 2010, 8:14
maybe some then ;o)
PostPosted: October 7th, 2010, 10:15
That's better :D
PostPosted: October 7th, 2010, 12:02
Send it to BlackST maybe he can help :D
PostPosted: October 7th, 2010, 17:35
DR companies would use a tool like PC3000 to manually clear the SMART status on the drives. Most would talk you out of doing so unless you were 100% sure the RAID card was at fault. Most often SMART indicates a drive failure and resetting it would not solve the underlying issue. Your case might be the exception. The process is quick, but it might cost $100 or so. Still, if you are able to get some life out of 2 SCSI drives it might be worth it.
PostPosted: October 7th, 2010, 17:51
If you expect PC3K SCSI to help.... :(
One thing is correct : must see why the SMART alert was triggered. Non-critical issues can be solved , otherwise it will be a cosmetic fix and the drive will turn into a time bomb if it is at end of life.
BTW : what drive/model are we talking about ?
PostPosted: October 7th, 2010, 18:31
my Crystal Ball says Seagate :OP
PostPosted: October 7th, 2010, 22:38
My ball say Fujitsu, 36 gb...
Users browsing this forum: Bing [Bot], Google [Bot], Majestic-12 [Bot] and 178 guests
