Forum rules
 Post subject: Info on 1.8 inch disks
PostPosted: August 4th, 2010, 13:47
Just collating info on 1.8 inch disks
The following site lists some good info on physical characteristics of many of the 1.8 inch drives
http://www.rockbox.org/wiki/HardDriveReplacement
I'm familar with the ZIF 40 interface, but not sure that the 50 pin one the earlier Ipod drives are supposed to have ?
Must be the one shown in
http://files.hddguru.com/download/Datas ... s-RevD.pdf
I'm still trying to identify which have 4k logical / 4k physical sectors
and also which have special firmware
(as per the following thread)
toshiba-apple-ipod-protected-harddrives-t10669.html
For a project I'm working on relating to true 4k logical / 4k physical
(as opposed to current Advanced Format 512 logical / 4K physical 512E)
Other related 1.8 inch info:
http://hddguru.com/software/2006.02.27- ... le-CD-ISO/
(fro detecting drive type)
 Post subject: Re: Info on 1.8 inch disks
PostPosted: August 4th, 2010, 13:53
other related info
toshiba-zif-drives-with-firmware-problems-need-help-t14477.html?hilit=MK8010GAH
PostPosted: August 4th, 2010, 14:02
Zune and Ipod replacemnt HD info on
http://www.rapidrepair.com/shop/zune-1g-30gb-parts.html
and related pages
PostPosted: August 4th, 2010, 14:04
Plus Toshiba spec sheets etc
http://sdd.toshiba.com/main.aspx?Path=H ... ifications
PostPosted: August 4th, 2010, 14:22
Looks like all the drives thar are > 512 bytes per sector internally, still only expose themselves as 512 bytes per sector logically
eg
MK1224GAH MK6024GAL
http://www3.toshiba.co.jp/storage/engli ... /24dvc.htm
Anyone know of any that natively expose > 512 bytes per sector logically ?
PostPosted: October 18th, 2010, 11:27
... And there's theres the 1.8" Samsung HS12UHE used in Macbook Air (see http://forum.hddguru.com/samsung-hs212uhe-connectivity-apple-macbook-air-t17010.html)
It has a LIF-connector with 24 ribbons in the cable. It’s just a SATA connector wired differently (and some power /ground) … at least that’s what I could get out of google and http://forums.macrumors.com/showthread.php?t=657341
(Been told there exist a small-LIF as well with an even smaller FCC-ribbon).
We haven't been able to find an adapter to SATA - but there is an usb adapter
http://www.mydigitaldiscount.com/SPD/runcore-1-8--sata-lif-usb-2-0-hdd-ssd-enclosure--80000D7A-1270043844.jsp
PAD-dataservice
http://www.pad-dataservice.dk
PostPosted: October 18th, 2010, 12:16
Adapter to SATA = wires + soldering iron
