Post new topic Reply to topic  [ 42 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: Samsung hdd HD753LJ Dead
PostPosted: April 16th, 2010, 5:58
So what ? Are you on top 10 now ? The day I will need your help I'll ask. I think that day cows will be laying eggs.
P.S. Horses do "perform" even in less than 2 min. , the fact that you didn't get an answer is just because I think you didn't deserve it. I have discussed it with people here other way. And do another thing : use ADD FOE, so you won't see my posts. I can do the same. Again, all your attempts to put people under a bad light have THE EXACTLY OPPOSITE EFFECTS.
"Hic Manebimus Optime"
PostPosted: April 16th, 2010, 6:14
I think someone needs to get a life. :roll:
PostPosted: April 16th, 2010, 7:10
I had a look and Guess what!??
Seems these are special Australian eggs LOL
I can't be arsed to do lots of links......
I have no comments on the above subject :O)
PostPosted: April 16th, 2010, 7:11
BlackST.. you the man! just Add Foe and relax. I know your 100%
PostPosted: April 16th, 2010, 8:06
ROTFLMAO !!!
:mrgreen:
PostPosted: April 16th, 2010, 13:56
Well ,
What Was So funny In This ,He Was Just Trying To Tell you the Meter Specs And Measurements Like He Wanted ,Its your Purgative to comply or not ,Making fun Is sick .Try a Protek 608 Multimeter and Watch The Fun One Of the Best Multimeter I Have ever seen In My Life
PostPosted: April 16th, 2010, 14:39
This is boring. If I wanted to find people who get boners over multimeters, I'd google it.
PostPosted: April 16th, 2010, 19:21
A first year electronics tech doesn't need to discuss multimeters with anyone, let alone a guru. :roll:
I asked you a simple question to ascertain the capability of your Agilent. I had absolutely no expectation that anyone would fail such a simple task. You made a statement which I believed to be false, akin to the Internet "bullshit" that you so often rail against, and I wanted you yourself to test it.
It takes more than $10K of equipment to be a "guru". You need to understand the principles behind their use. For that you need to go to school. I learnt part of my trade from people who were much less academically qualified than myself. But I was their willing pupil and they were my gracious tutors. I thank them for their patience and understanding.
You and your colleagues need to come down from your high horses (or stallions) and be receptive to the complementary knowledge that people who you deem inferior to yourselves can provide.
Some of us are born intelligent, others not so intelligent, but all of us, including "gurus", are born ignorant.
PostPosted: April 17th, 2010, 2:27
Now you are harassing. I told you to add foe and ignore, I was doing the same. But you don't stop. This is what you expect : attention on yourself. But I won't play your game. Don't use my username to answer again or to post your personal considerations about my person. It's so simple : both should think and do as each other has never existed. Ok?
P.s. Many people here know exactly and directly what equipment I own - a lot more than 10k$. Ask them for confirmation if this makes you feel better or helps stopping this annoying discussion.
PostPosted: November 2nd, 2010, 4:51
Hello friends
i received a samsung SP0411N.
each time i plug into power it shorts the computer.
i tried to power only mbo (without hda) and same short occurs.
it's probably mbo.
does any one have an idea trying to fix it?
tks u all
ephraim
PostPosted: November 2nd, 2010, 8:27
TVS
Search it
PostPosted: November 2nd, 2010, 8:30
And if TVS are not enough....
PostPosted: November 2nd, 2010, 9:09
hi friends
tks Blackst and pcimage.
i searched this site and didn't find ant thread regarding this samsung sp0411n.
can u be more specific.
tks
ephraim
PostPosted: November 2nd, 2010, 10:18
hi friends. (mistake in my last message)
i searched this site and didn't find ant thread regarding this samsung sp0411n TVS.
i apologize.
tks
ephraim
PostPosted: November 2nd, 2010, 10:39
Just search TVS
PostPosted: November 2nd, 2010, 12:56
tks pcimage
i was searching all hddguru. nothing. after googling around i found a nice article on tech support.
they recommend to take out the tvs diode, recovering, freezing etc.
just to be sure where is this tvs diode ?
http://www.techsupportforum.com/hardwar ... 0411n.html
tks a lot again
ephraim
PostPosted: November 3rd, 2010, 2:49
Refer to the following photo clip:
http://www.users.on.net/~fzabkar/HDD/SP0411N_TVS.jpg
To test the diodes, use a digital multimeter on the 200 ohms range. The blob to the right of the zero ohm resistor is a mystery to me, but it may just be a tarnished copper pad, possibly set aside for a fuse.
These URLs should help you identify the components:
http://www.users.on.net/~fzabkar/HDD/HDD_ICs.txt
http://www.users.on.net/~fzabkar/HDD/TVS_diodes.txt
If you have difficulty using your multimeter, one of us will help you.
PostPosted: November 3rd, 2010, 4:48
hello fzabkar
thanks again for your reply.
the picture u sent doesn't clarify which is the TVS?
i believe the procedure mentioned on http://www.techsupportforum.com/hardwar ... 0411n.html
is risky. isn't it?
tks again for all of u there
ephraim
PostPosted: November 3rd, 2010, 5:27
Do you have a multimeter?
What procedure are you talking about? If you are referring to freezing, then that technique was claimed to free a stuck spindle. It has nothing to do with your problem. OTOH, if you are referring to removing a TVS diode, then that is OK provided that your power supply is good. Be aware that if your drive suffers an overvoltage in the absence of a protective diode, then more serious damage will result.
PostPosted: November 3rd, 2010, 5:44
fzabkar tks
just which is the TVS? where is it located on this mbo?
tks again
ephraim
Users browsing this forum: No registered users and 243 guests
