 Post subject: WD1500ADFD. MHDD. Many UNC in succession.
PostPosted: December 16th, 2010, 1:38
Hi! I have a problem with the WD1500ADFD. I turned off the computer before it complete its work. After that, it can not boot. I did a test drive using chkdsk. Everything was fine. Windows was start successfully. Then I turned off the computer normally. But then it can not boot again. Chkdsk was not help and hung at 25% after many hours of testing. Then I run MHDD with the option of REMAP. Somewhere on the fifth line started to appear UNC sectors one by one. For several hours it found more than a 20 in a row. I canceled the scan. What can I do? There are not important information. I want to restore the hard drive itself.
 Post subject: Re: WD1500ADFD. MHDD. Many UNC in succession.
PostPosted: December 16th, 2010, 5:53
Heads were writing while the drive shut down. Mhdd and co. can do little, a special procedure can fix everything but not at user level. Refer to the nearest pro , he will know what to do and the quote I am sure is honest. Other methods are only cosmetic.
PostPosted: December 16th, 2010, 6:03
Try to clone it on another disk.
Use DMDE or HDCLone
data recovery Poland
PostPosted: December 16th, 2010, 6:15
Thanks! But I do not need to save data from HDD, I need to repair HDD to use it more (reinstall windows etc).
PostPosted: December 16th, 2010, 10:31
А что смарт винта показывает?
Винт , возможно, уже умирает. Вы хотите его отремонтировать самосточтельно что-ли? Винту нужно запускать заводской скан , но это ,зачастую, уже как мертвому припарки. На эти диски, если не ошибась, давала больше трех лет гарантии, рекомендую поменять его.
Angel Data Recovery
PostPosted: December 16th, 2010, 10:57
S.M.A.R.T. is on the picture.
MHDD in ERASE mode failed at first UNC-block.
PostPosted: December 16th, 2010, 11:39
I found the warranty card of the hard drive. It was bought in 2007. The warranty period is 12 months. Although the factory warranty is 5 years old.
What else can I do?
PostPosted: December 16th, 2010, 12:30
If ERASE fails, there's little to do (at user level). The problem is a bit complex and unfortunately I cannot explain it here :(
Users browsing this forum: Google [Bot] and 130 guests
