 Post subject: Momentus 5400.6 500gb
PostPosted: December 21st, 2010, 10:55
Hi all
I have a problem with my hard drive not being recognised by computers, when connected to a pc it is not detected by the bios and the bios takes a long time to progress / freezes, I have tried of a few computers and get the same result
The drive seams to power up ok and spin up for a few seconds then spins down and stops
I think maybe I can recover the data by replacing the PCB
The details are
pn 9hh134-567
fw 0002bsm1
pcb 100536284 g2 e009fu3e
http://i41.tinypic.com/2irn2pd.jpg
Which component on the board is the fuse the white one with 8g on it in green?
 Post subject: Re: Momentus 5400.6 500gb
PostPosted: December 21st, 2010, 16:41
It's not the PCB, it's the heads.
99.9% sure you are barking up the wrong tree I'm afraid :-(
PostPosted: December 21st, 2010, 16:51
If the drive spins up, then the fuse, if one exists, must be intact. The TVS diode must also be OK. In fact I can't see any fuse -- the 5V TVS diode appears to be directly connected across the supply. FYI, the TVS diode is the horizontal device under the SATA power connector, with a "v" on the PCB indicating the cathode (striped end).
The white device is a shock sensor. It is mounted at 45 degress on order to sense vibration in both horizontal axes.
If you insist on trying a new PCB, then you will need to transplant the 8-pin serial flash memory chip at the bottom right corner from patient to donor. This chip stores unique, drive specific information.
PostPosted: December 21st, 2010, 17:25
ok thanks
is their a way to fix this head problem?
thanks
Graham
PostPosted: December 21st, 2010, 17:27
test results
--------------- SeaTools for Windows v1.2.0.4 ---------------
21/12/2010 21:27:33
Model: ST9500325AS
Serial Number: 6VE2BWZL
Firmware Revision: 0002
Short DST - Started 21/12/2010 21:27:33
Short DST - FAIL 21/12/2010 21:27:34
SeaTools Test Code: A2F0DCE4
PostPosted: December 21st, 2010, 18:00
The drive is picking up it's serial number from the PCB, this series have the s/n programmed into it. This is why Frank is saying you have to move the ROM chip when you change the PCB, which he is perfectly correct in.
But IMHO this would be a fruitless mission, as it's almost definitely a heads related issue and requires a head change in a cleanroom environment. Also, these series of drives are very fussy when it comes to head compatibility.
By all means give it a go, but if you do mess up that ROM you'll virtually ruin ALL chances of recovery.
Sorry to appear so pessimistic, but it's the case for this drive :-(
PostPosted: December 21st, 2010, 19:08
Ok so I can forget the idea of replacing the PCB as it is 99% not the problem
I have made a sound recording of the drive http://www.youtube.com/watch?v=4oppChpij1Y
Working on the heads is not going to be something I can do from the sounds of it, what other options are there?
Will putting it in the freezer for 24 hours give me enough time to get the data off?
PostPosted: December 21st, 2010, 19:26
No, you have to keep it in the freezer for at least 25 hours.
PostPosted: December 22nd, 2010, 2:21
I would say 42. Also meditation and new age stuff helps... :mrgreen:
PostPosted: December 22nd, 2010, 3:58
I've never had any help with less than 48 hours, but you have to tap it genitally on it side on that specific semi-hourly interval to get the full effect.
:shock: :shock: :shock:
EDIT: (Feeling guilty, please do not attempt my B.S.'d attempts)
PostPosted: December 22nd, 2010, 9:47
You have to do what to it's genitals?!?!?!?!?!?!?
PostPosted: December 22nd, 2010, 9:54
If you have the data recovery spray, you can cut the freezer time in half.
Seriously, though. If your data is important to you, send it to a professional before it is completely unrecoverable. Every time you power on the device, you could be causing severe damage to the drive's surface.
As for the freezer, it will only help make things worse.
PostPosted: December 22nd, 2010, 11:59
ok do people here from uk companies who can do the work on the heads want to suggest a price and time scale for me to consider
thanks
PostPosted: December 22nd, 2010, 13:45
You mean this ?
http://www.youtube.com/watch?v=3Qk8p8_eysc
:mrgreen:
(or was it a freudian lapsus ?!?)
PostPosted: December 22nd, 2010, 13:52
:shock:
PostPosted: December 22nd, 2010, 14:13
BlackST wrote:
You mean this ?
I guess he meant you need to tap the drive with your genitals :mrgreen:
It's a new croquet game :twisted:
PostPosted: December 22nd, 2010, 14:30
Maybe billiard then :mrgreen:
PostPosted: December 22nd, 2010, 14:58
Depends on how erective you are about your recovery :mrgreen:
PostPosted: December 22nd, 2010, 16:50
Hi
thanks for the replies
i have decided against any futher investigation of the drive myself, im only now looking for people to offer quotes for the work
thanks
PostPosted: December 26th, 2010, 20:48
actually this freezer tip (w/o genitals) worked for me to save and recover data off a non bootable disk ...
http://rzr.online.fr/q/2inch5
Please (free) help :
http://rzr.online.fr/q/hdd#
how to unlock/format ST3120026A in max security ?
"ALPINE - 1_Disk M.14 01-16-03 11:51"
Users browsing this forum: qwest01 and 74 guests
