 Post subject: Problem: Extremely low read speeds on Samsung 2TB
PostPosted: January 5th, 2011, 9:39
Hello gurus,
I have been struggling with this problem for a while now, I tried some forums but nobody seems to know what's
going on. I hope some guru here can help me! I have a system with the following setup:
AsRock K7vt4a pro
AMD Athlon XP 3000+
2x1GB PC3200 DDR1 (Running at 2700)
Eminent PCI Sata controller
Samsung 2TB Spinpoint ECO Green (HD204UI)
Windows Server 2003 (Fully updated)
I have hooked up the Samsung 2TB disk and another 1TB Seagate disk to the sata controller. Now when doing
benchmarks I get the following results:
Seagate 1TB
Samsung 2TB
Since I'm using a SATA2 HDD on a SATA1 controller (through PCI) I wasn't hoping for breakneck speeds, but this
is crazy. I'm struggling to figure out why the read speed is so slow: I'm not even getting 4 MB/s. At first I
thought the Samsung disk was misaligned, but that can nowhere near explain the slow speed. :(
Does anyone have a clue what might be causing this? I have checked:
- The V-Raid software that comes with the controller shows both drives are running DMA mode
- I tried the controller+2TB HDD in a different computer (Win7), where I reached 80+ MB/s, both reading and writing
So I'm starting to think its an issues with Win2003...
Thanks for any help!
Sav
 Post subject: Re: Problem: Extremely low read speeds on Samsung 2TB
PostPosted: January 5th, 2011, 23:15
Download MHDD and test your HDD from there. it is here on the forum. Try it and see what you find out.
Iorana Haraharaini
PostPosted: January 6th, 2011, 5:47
Are you running the drive in SATA II mode? There is usually a jumper you can put on to switch modes on the drive. If you are running the drive in SATA II mode on a SATA I Motherboard this may be the problem.
https://www.mjm.co.uk/
Users browsing this forum: Bing [Bot], Google [Bot] and 219 guests
