 Post subject: ST32000641AS recognize as "ST_M13FQBL"
PostPosted: January 11th, 2011, 20:25
Hi
First of all, sorry I'm french so my english is not very good...
I have just bought a Seagate Barracuda 2 TB XT, and my Bios recognize it as ST_M13FQBL with 0Mb.
I tryed to change cable, put it on SATA III, SATA II... but nothing.
And when I switch on the comp, the drive spin up...
A little of help would be grateful !
Thanks!
 Post subject: Re: ST32000641AS recognize as "ST_M13FQBL"
PostPosted: January 12th, 2011, 3:59
And then what?
Normal calibration sounds, or some ticking with spin down?
PostPosted: January 12th, 2011, 4:15
You should check the log (terminal) report of that one to understand better what's wrong.
Or else, take it to a pro who can help to understand what's the problem.
PostPosted: January 12th, 2011, 6:37
It spine up 5 second and then return to normal sound.
I think I'm just going to return it...
PostPosted: January 12th, 2011, 6:41
If you don't need the data on it, just deliver it for warranty.
PostPosted: January 12th, 2011, 6:46
There's no data on it, it never worked...
PostPosted: January 12th, 2011, 6:52
Nice, so it's easy. Go for warranty.
PostPosted: January 20th, 2011, 11:23
They gave me a new one and it works ^^
PostPosted: January 20th, 2011, 15:50
Root cause for that behaviour is most probably a misplaced pionter, which points to sector 0 (firmware area) instead of sector xx, which is the beginning of user area. I saw that several times at Seagate drives, also newer WDs had these effect.
Regenerate translator - voilá! This is nothing for normal computer users, but every pro is (should be) able to solve that problem quick.
Users browsing this forum: Google [Bot] and 161 guests
