Post new topic Reply to topic  [ 90 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: Samsung hd502hj
PostPosted: January 21st, 2011, 5:28
eBay (Germany) showed 50 HD502HJ, and 3 HD503HI. If you search not only the headline, you'll find much nore, e.g. 86 HD502HJ.
PostPosted: January 21st, 2011, 7:42
ok thanks for info.
I received some mails of shops in holland they have possible good donors, 2010.10 rev A. i'm asking for picture of PCB now, awaiting answer.
I have a OCZ stealth Extreme PSU, not very cheap, BTW.
PostPosted: January 21st, 2011, 8:19
A huge PSU must not e.g. fit to an office PC - PSU and PC power consumption should be equivalent. If a PSU runs with 60%..80% load, it fits best. Otherwise it is like driving Porsche in a city.
PostPosted: January 21st, 2011, 9:26
got a 500W PSU, and a ATI 4830 Overclocked and AMD Phenom x4 9650, so i don't think PSU is too big.
BTW i got mail back from webshop, don't think this PCB will work on my HDD, what do you think???
It's a Rev 01 R00 PCB, mine is Rev 02 R00. I see different MCU i guess.
PostPosted: January 21st, 2011, 10:15
Fact is, your PSU and / or hdd internal voltage transformers generated voltage spikes, because a TVS will NEVER die without overvoltage. You can measure that with an oscilloscope, to be sure.
To the PCB: Please try it, or buy a 100% fitting PCB. eBay is a good source.
PostPosted: January 21st, 2011, 11:44
_TK_ wrote:
....because a TVS will NEVER die without overvoltage.
Yes i Understand, PSU is being replaced, i also had an other 500W PSU.
I think i'll wait with the PCB shown on picture, just to be sure. I'm looking if i can find something closer to match.
PostPosted: January 24th, 2011, 9:55
hmm, can't seem to find an F3_1D rev 02 PCB in Holland.
all my returning emails from shops are rev 01.
guess it's time for reverse engineering my pcb
PostPosted: January 24th, 2011, 11:44
Try searching in Belgium, or Luxemburg... :?
PostPosted: January 28th, 2011, 12:06
Yes, i found an donor HDD, with PCB F3_1D rev 02.
So it's the same, do i HAVE to swap U12 serial flash ROM or can i try it first without swapping??? Or will it do more damage???
It's not that i can't remove the ROM, it's more simple without doing it.
PostPosted: January 29th, 2011, 10:18
no-one???
PostPosted: January 31st, 2011, 17:21
really???
No-one or don't wanna answer???
too bad.
The donor is coming in a week, it's shipping in two days so maybe friday i can try to recover my data.
PostPosted: January 31st, 2011, 17:34
Good luck, then.
If it works, don't forget to play also lottery same day as the chances are on your side but it will not last longer.
If it doesn't work, it's just because good will is not enough , sometimes. But keep trying. 8)
PostPosted: January 31st, 2011, 18:35
how much higher are the changes with swapping ROM U12???
or is it absolutely nescesarry(?)
PostPosted: February 1st, 2011, 15:46
The answer will automatically come out from Friday going on ! 8)
PostPosted: February 1st, 2011, 18:27
the question was: If i don't swap the ROM can it damage other component of my drive????
read something about data being written to NVRAM and you end up with two dead drives.
That's all i needed to know.
PostPosted: February 1st, 2011, 18:34
another question, any chance of successful PCB swap?
dead drive: HD502HJ
PCB: F3_1D rev.02
Sata connector sticker: PEFZE1A5D21696
PR. Date: 01-2010
Donor drive: HD502HJ
PCB: F3_1D rev.02
Sata connector sticker: PMM3EC58B22971
PR.Date: 12-2010
PostPosted: February 25th, 2011, 12:03
so i got my donor drive in and swapped pcb's.
Dead drive spins up now but bios doesn't go any further.
donor drive with old pcb, doesn't work, no spin up nothing.
so i think there's something with my pcb, haven't swapped serial flash rom BTW.
Maybe next step???
PostPosted: February 25th, 2011, 12:21
You were adviced enough...
PostPosted: February 25th, 2011, 12:46
are you enjoying your answers BlackST????
why do you even reply at messages in the forum.
All you need is an automatic reply service with "Give me money, i'll fix it"
You're not quite helping here.
PostPosted: February 25th, 2011, 13:00
I don't want to handle your case in any way. You asked how to fix the pcb, it was not fixable by you and you were told about the chances. Then you asked what could be the donor, and you were adviced about being a waste of time and money, the donor by itself didn't work. Really want DIY? All you have to do is try at your own risk and expense. To me it could have been fixed perfectly right from the start...
Users browsing this forum: No registered users and 72 guests
