 Post subject: Windows xp not install in new Seagate 500 GB sata hard disk.
PostPosted: February 20th, 2011, 0:24
I assembled new computer with core i7 2600 processor and Intel DH67BL motherboard.
When tried to install windows xp sp3 in new sata 500GB hard disk, it is not install and massage comes hard drive is curept.then I replace another new 500GB hard disk but same massage comes again.
Plz help me what is actual problem? And how to sort out it?
Thanks guys in Advance :(
 Post subject: Re: Windows xp not install in new Seagate 500 GB sata hard disk.
PostPosted: February 20th, 2011, 2:33
Please explain why you think this is a disk-related problem, which is relevant to this forum? You have tried another disk drive and the behaviour did not change, so it seems that (unless both disks have an identical problem - which is unlikely), the disks are not at fault here.
If I was in your situation, I would be researching that motherboard, and seeing whether it needed extra WinXP drivers, especially when using any of its fancy SATA functionality.
Google is your friend :) Have a look at the Intel site for those WinXP drivers... I found what looks to be the correct drivers within 2 mins of searching.
PostPosted: February 20th, 2011, 4:11
are you using a backup copy of windows xp
as some copies do not have any drivers for sata drives
that where your problem will be
like vulcan says
its very unlikely that both hard drives have identical problems
PostPosted: February 20th, 2011, 5:27
Temporarily reconfigure your SATA controller for IDE, legacy, or compatibilty mode in your BIOS setup. This will make your SATA drive appear as the older IDE type.
If your Windows installation then proceeds without problems, I'd be looking for Windows XP preinstallation drivers for your motherboard chipset.
PostPosted: July 8th, 2011, 21:53
hi surya
what is the status ..
what did you do update information...
i am having the problem same as yours with i7/dh67blb3 and 500gb sata Hdd..
thanks for the information to one and all...:) :)) :)
sri
PostPosted: December 15th, 2011, 7:58
hi
my problem solved y setting in the bios with the other option from AHC to IDE ..
this helped in installing and running cool and i faced lot of hanging whic i later found to be one of the locks for the cooler which are 4 is loose..
i turned the stock cooler of i7 2600k turning the lock.. solved the hanging of the system problem solved till now i did not face hanging or blue screens after that from 1month...
thanks to all
sri :D :D :D :D :mrgreen:
