 Post subject: FUJITSU MHT2060AT
PostPosted: February 20th, 2011, 17:51
I have this FUJITSU to recover the data, but clicks several times and power down.
We need to copy the ROM from PCB?
Best Regards,
Neuron
 Post subject: Re: FUJITSU MHT2060AT
PostPosted: February 20th, 2011, 21:32
Need to check for media damage, IMHO.
http://www.datasaversllc.com
PostPosted: February 21st, 2011, 15:02
Hi again Jono,
Thanks for your info.
Firmware or platters or heads.
I will check inside the disk.
Thank you
Neuron
PostPosted: February 21st, 2011, 17:44
Heads / platters. Look for a thin ring of damage.
PostPosted: February 22nd, 2011, 19:21
Yes I know ... the ring with special effects, if we turn the disk ... and light.
But sometimes this disks have problems with firmware? Or IC?
What is more common in this ones MHT...?
Best regards,
Neuron
PostPosted: February 23rd, 2011, 9:36
Bad heads / media damage most common.
In trying to "diagnose" a hard drive remotely, playing the "odds" is useful, but you understand that it cannot be definitive, right? Nothing works better than examining the drive itself with the appropriate tools.
PostPosted: February 23rd, 2011, 17:49
Yeap that's the procedure ... check inside.
Best regards,
Neuron
PostPosted: March 14th, 2011, 14:15
Heads ok,
And no "thin ring of damage".
Best Regards,
Neuron
PostPosted: March 14th, 2011, 18:00
How have you determined the heads are bad? And can you see more than the top platter surface?
PostPosted: March 16th, 2011, 9:55
Thanks for your comments,
The heads - inspect with magnifying glass.
At moment no hardware/software to see read/write stat.
This a two dishes, the top is ease, the other faces with a mirror. Can't see the last face - the second dish.
Another procedure?
Best regards,
Neuron
PostPosted: March 16th, 2011, 10:07
Assuming you have the proper gear and experience, try a head swap. If the new heads fail, there was probably media damage. Re-test them in the donor drive. If not, you should be able to get your data.
PostPosted: March 16th, 2011, 18:33
Try that when I get a donor drive.
Many thanks for your advices and info.
Neuron
PostPosted: March 20th, 2011, 20:22
Another week, another MHT2060AT
This time - PART NO: CA06297-B306
2004-04
Someone scratch the PCB in dis / assemble the notebook.
It is possible exchange the PCB from the other one (PART NO. CA06297-B046, DATA 2003-10) that I report with problems?
Neuron
PostPosted: March 21st, 2011, 4:27
MHTs have ROM chips. The firmware version must be the same.
PostPosted: March 22nd, 2011, 9:53
Thanks,
Please provide more info about the chips and firmware.
I have the REV. NO. We need to check this? to match.
Best regards,
Neuron
PostPosted: March 25th, 2011, 17:43
Many thanks nande.
More detail on disks:
Disk1 with clicks (dish spins and heads after 4,5 times go to park zone, platters spin cont.):
FUJITSU
Model: MHT2060AT
PART NO: CA06297-B046
DATA: 2003-10
60GB
0FE5 - 009B
CA21325-B12X
Disk 2 (scratch - PCB)
FUJITSU
Model: MHT2060AT
DATA: 2004-04
60GB
0F5B - 0022
CA21325-B13X
Thank you very much,
Neuron
Users browsing this forum: Google [Bot] and 54 guests
